Nebraska where you at???
Discussion in 'Mid West' started by Black3144, Sep 9, 2011.
  1. Jan 8, 2020 at 6:16 AM
    #1321
    GQ7227
    GQ7227 mw survivor
    J A Y
  2. Jan 8, 2020 at 6:31 AM
    #1322
    GQ7227
    GQ7227 mw survivor
    J A Y
    i had a long discussion at ToyoTechs yesterday regarding the suspension on my old as dirt Tacoma and dealing with the crap local roads and highways here.
    he said that my front suspension is 'probably just fine' and that spending well north of $1000 to get new OEM parts (shock absorbers,LBJs, etc.) would probably not make much of a difference in driving on these roads...
    here are a few I frequently travel on:
    i80 from i480 all the way past 84th in both directions across all lanes ... that is about 5 miles!!!
    US75 from Offutt area all the way through south O to 480, both directions ... but it is definitely much worse going north
    L street ... from 84th all the way to i680 and to 120th
    90th street... pretty much from west Center all the way to Fort
    I also travel down w Broadway in the Bluffs occasionally but it seems they are 'trying to fix' that mess up somewhat
    what am i supposed to do :confused:
    these roads 'should be' as smooth and safe as the recent drive to Fremont on 275 was
  3. Jan 8, 2020 at 6:48 AM
    #1323
    Shellshock
    Iowa
    Put on some after market 2.5s. It’ll be dreamy.
  4. Jan 8, 2020 at 6:51 AM
    #1324
    GQ7227
    GQ7227 mw survivor
    J A Y
    would i have to 'lift' my suspension to do that, i really don't know much about this area
    he looked at aftermarket shock absorbers when I asked him if there was anything better out there for ride quality but he could not find anything better than OEM absorbers for my truck and to keep it at stock height
  5. Jan 8, 2020 at 6:57 AM
    #1325
    Shellshock
    Iowa
    Nope. You can stay at stock height.
    GQ7227[QUOTED] likes this.
  6. Jan 8, 2020 at 7:00 AM
    #1326
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have a link of what exactly you are looking at with 2.5s
    my search button does not return anything of use
  7. Jan 8, 2020 at 7:06 AM
    #1327
    Shellshock
    Iowa
  8. Jan 8, 2020 at 7:49 AM
    #1328
    GQ7227
    GQ7227 mw survivor
    J A Y
  9. Jan 8, 2020 at 7:51 AM
    #1329
    Shellshock
    Iowa
  10. Jan 12, 2020 at 10:02 AM
    #1330
    GQ7227
    GQ7227 mw survivor
    J A Y
    heard anything about King performance shocks :notsure:
    here ... quite pricey they are
    i basically offroad here at 60+ mph ,,, it takes its punishing toll :(
    Features for Part #25001-302
    • Elevate your on- and off-road performance with King OEM Performance Shock Upgrade Kits
    • OEM upgrades built with the same quality materials & precise tolerances of King’s high-end shocks
    • Rigorously-tested to develop the optimal damping curves and spring rates for your vehicle
    • Offer an adjustable ride height and up to a 25% increase in wheel travel (15% increase for most rear kits)
    • Large diameter shock bodies and external reservoirs dramatically increase fluid capacity (option varies by model)
    • Improved heat dissipation for sustained damping performance under even punishing conditions
    • Serviceable design allows for valve adjustments with simple hand tools
    • Designed to simply replace your factory shocks and struts
    • Kits come complete with everything for 100% bolt-on installation with no cutting or welding
    • Your King OEM Performance Shock Upgrade Kit is backed by a 90-day limited warranty
    King OEM Shock Upgrade Kits deliver sustained damping performance under even the most grueling environments.
  11. Jan 12, 2020 at 10:24 AM
    #1331
    Shellshock
    Iowa
    Get yourself some King’s and long travel and you won’t even know there’s bumps in the road. Don’t forget the 35s to roll over everything.
    @Sociopenguin @jeff b @mcharfauros @Cav_BluTRD @Tigerian @Tacomania @CygnusX191
  12. Jan 12, 2020 at 10:35 AM
    #1332
    GQ7227
    GQ7227 mw survivor
    J A Y
  13. Jan 12, 2020 at 11:41 AM
    #1333
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Tigerian and Shellshock like this.
  14. Jan 12, 2020 at 11:53 AM
    #1334
    GQ7227
    GQ7227 mw survivor
    J A Y
  15. Jan 13, 2020 at 3:28 PM
    #1335
    GQ7227
    GQ7227 mw survivor
    J A Y
  16. Jan 13, 2020 at 3:28 PM
    #1336
    uploadadventure
    Dixon, Mo
  17. Jan 13, 2020 at 3:29 PM
    #1337
    GQ7227
    GQ7227 mw survivor
    J A Y
    i should probably drive 150 mile and check it out for him first
  18. Jan 13, 2020 at 3:31 PM
    #1338
    uploadadventure
    Dixon, Mo
    I agree. Maybe he can meet you. @Shellshock did want a regular cab truck.
  19. Jan 13, 2020 at 3:32 PM
    #1339
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is major coin for a little 4cyl!
  20. Jan 13, 2020 at 3:33 PM
    #1340
    GQ7227
    GQ7227 mw survivor
    J A Y
    i'm gonna run that VIN on a carFax
    5TEPM62N21Z762214
    see if its a pure Cornhusker truck or not
