Necessary Maintenance at 30K?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tmz1m, Mar 7, 2017.
  1. Mar 7, 2017 at 7:29 AM
    tmz1m
    tmz1m [OP] Well-Known Member
    I'm at 33,000 miles on my 2016 and just brought it in for an oil change/tire rotation this morning. The service adviser tried to upsell me various services -- 4x4 service, fuel injector service, etc... I declined all today, but will get anything necessary completed the next time I'm in. He also mentioned they recommend rebalancing my tires every 10K miles, and a new alignment every 15K miles. That seems excessive -- I normally balance and align when I get new tires and not at other intervals.
    What are the services I REALLY should get done and at what intervals?
  2. Mar 7, 2017 at 8:05 AM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Sounds like you need a new service department to me.....
  3. Mar 7, 2017 at 8:10 AM
    Storman
    South Western PA
    I would refer to my owners manual for this, you should check it out....its probably in your glove box under the heading....scheduled maintenance.
    tcjacado, dYL0n, hiPSI and 4 others like this.
  4. Mar 7, 2017 at 8:25 AM
    DarthMinnow
    DarthMinnow Well-Known Member
    '16 Tacoma TRD Sport 4x4 AT
    I worked at a Toyota dealership as a lube technician. They tell you all those things because they are required to by management. Only thing he said that sounds weird was rebalancing the tires every 10K miles, and a new alignment every 15K miles. You don't need to rebalance tires unless issues are arising. Same with an alignment. Only reason to get one if your car doesn't drive straight or uneven wear on the tires. The rest of the maintenance I would do if you plan on keeping the truck till it blows up 250k+ miles down the road.
    PROseur likes this.
  5. Mar 7, 2017 at 8:32 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    here is a snap of the 30k service off the maintenance manual!
    ShemRahBuck likes this.
  6. Mar 7, 2017 at 8:35 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    When do you have to change plugs on the 3rd gens?
  7. Mar 7, 2017 at 8:44 AM
    tmz1m
    Helpful, thanks.
  8. Mar 7, 2017 at 8:44 AM
    tmz1m
    It was a particularly weird request when the guy had just complimented me on my stock tires holding up so well and wearing so evenly...
  9. Mar 7, 2017 at 9:02 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    I changed out my:
    M/T fluid *
    front and rear Diff fluid (front was black) *
    lube * and oil and filter
    top off fluids
    rotate tires
    * Did these myself all at 15K miles. The others at 20K and will do all again at 30K but all myself. Overkill yes... but drive truck and wheel some .... good to get under work on it and take a look see for rust and whatnot.
    No alignment no tire balancing... that a bunch of hooey, did they offer to change our tail light lube too? sheesh.
    shakerhood and Storman like this.
  10. Mar 7, 2017 at 9:04 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I rotate my tires every 5K and balance at 10K
  11. Mar 7, 2017 at 9:10 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Every 50-60k is typical for most vehicles, not sure what they "recommend" for the new motor on tacoma.
  12. Mar 7, 2017 at 9:17 AM
    Broccoli
    Airdrie Alberta
    Plugs are easy tho, i do mine every 50000km roughly 32000miles. But will be fine for longer.
  13. Mar 7, 2017 at 9:21 AM
    IPNPULZ
    going to be fun!
    I dont have the manual in front of me but I think I remember reading 60K for plugs....
    shakerhood likes this.
  14. Mar 7, 2017 at 9:23 AM
    Broccoli
    Airdrie Alberta
    My question is this, for anyone doing plugs why would you get oem replacements (denso) instead of iridium or platinum plugs? For a minimal differance in price?
    Sorry for the thread jack op:) :threadjacked:
  15. Mar 7, 2017 at 9:44 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    You can download a PDF copy of the whole thing if you're unable to find the paper copy you were given with your truck.
    toyota.com/owners
  16. Mar 7, 2017 at 9:59 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Whats wrong with Denso?? I think my Honda has 100K on them still going strong too..
    blackcloud08 and Storman like this.
  17. Mar 7, 2017 at 10:42 AM
    Broccoli
    Airdrie Alberta
    Nothing but there nothing special either, plain jane copper tops... its all about that ngk!!
  18. Mar 7, 2017 at 10:43 AM
    Broccoli
    Airdrie Alberta
    Platinums or iridiums have a faster spark, better detonation etc.
  19. Mar 7, 2017 at 10:48 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    OK I was confused cause the Denso also comes with Iridium versions and what I used in the past.
  20. Mar 7, 2017 at 11:04 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    I've been changing my own engine, transmission, and diff fluids every 30k (engine every 7,500) myself since I bought my G2. I also changed everything after break-in at 5k. You'd be amazed how much metallic shavings & bits are stuck to your diff drain plug after break in. Engine and cabin air filters are simple too.
    Throw a bottle of fuel system cleaner in every 10 tanks or so to cover that.
    I've never had an alignment done. Never had my tires re-balanced. Got around 60k on my original tires, Michelin replacements now have 90k on them and still have lot's of life (my truck has an easy highway life; still on original brakes after 155k).
    Half the reason I love my truck is that a dumb-ass like myself with zero mechanical skills can easily do all this stuff myself. I'd love to know what the dealer charges for all these services, and how much I've saved over the years. I did bring it in to the dealer one time, to replace a wheel bearing that bit the dust, and had them replace plugs, flush coolant, and new belt. To this day I feel like a robbery victim from that visit.
    granitemetaltaco and bobrown14 like this.
