Necessary to change the UCAs for lift and more clearance?
Discussion in 'Suspension' started by kevin.amaru, Apr 28, 2023.
  1. Apr 28, 2023 at 9:26 PM
    kevin.amaru
    kevin.amaru [OP] New Member
    Kevin
    Tacoma
    hey y’all,
    i have a 2019 cement grey tacoma sr5 and i’ve already done alot to it, chrome delete inside and out, new headlights, taillight, fog lights, installed ditch lights and prinsu roof rack with light bar, and added seat covers among other small things. i wanna get a lift and bigger tires but i’m sure as everyone knows there are alot of options. i don’t haul alot of weight and i don’t go heavy off-roading much (i drive on the beach A LOt and some easy mud / dirt trails) so essentially any ideas on what i can do to get the aesthetic look of a lift and bigger tires, while functionally getting more clearance without changing out the ucas? or does that have to be done? i don’t wanna spend $5000 on a lift and suspension if i don’t actually NEED the new suspension built for heavy off roading and heavy loads.
    cheers, kevin
  2. Apr 30, 2023 at 8:00 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    Welcome.
    You shouldn't have any issues, or need UCAs if you keep the lift under 2" and positive offset wheels.
    kevin.amaru[OP] and tcBob like this.
  3. Apr 30, 2023 at 8:21 AM
    kevin.amaru
    Kevin
    Tacoma
    that’s good to know, do you know what size tires would fit a 2” lift without having to trim anything? i think i saw 275’s is the biggest and 285’s would rub but that may not be true
