necessary to drain rear diff?
Discussion in 'Technical Chat' started by jrukus, Sep 13, 2008.
  1. Sep 14, 2008 at 11:25 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    If your front breather is located under the hood then you wouldn't need to change the fluid. I also believe your tranny and trans. are fine.
  2. Sep 14, 2008 at 11:40 AM
    jrukus
    jrukus [OP] jason r
    queen charlotte islands
    black '08 trd tacoma
    285/70/17r tires on stock rims, sirius radio
    Do you mean if I have already done the extension in the front under the hood? Or do you mean that the front diff breather is already in a safe place? Cause the riverI went through was plowing up to my headlights in the front and about 3 inches from the bottom of the doors on the side.
  3. Sep 14, 2008 at 11:56 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i would do the front diff breather mod also, and i would go ahead and change my diff fluid in the front also...same as front...water gets in there, and them gears are gonna be fubarred!!!
  4. Sep 14, 2008 at 12:01 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I thought that the diff breather was already safe?
  5. Sep 14, 2008 at 12:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, I went on an off roading weekend, much of wich was in water. Moday I decided to check the gear fluids. When I drained the rear, the oil looked like milk. Its an easy change, and always better to be safe, than sorry. :)
  6. Sep 14, 2008 at 12:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly....i havent looked on the 05+ tacomas to see where the breather location is. if its like the first gens.....it needs to be done.
  7. Sep 14, 2008 at 12:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Second gens have the front diff breaher extended on the driver side fender well. :)
  8. Sep 14, 2008 at 12:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool. something less for the 2nd gen guys to have to worry about.
    hey chris......what about the tranny and transfer case? where are the breather on those.....are they extended??
  9. Sep 14, 2008 at 12:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive the Transfer case is, and its right next to the front diff. Tranny and rear diff arent. Not sure why. :confused:
  10. Sep 14, 2008 at 12:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i gotta extend mine on my 04 pretty soon. im gonna have to see if i can find the correct part numbers so i get the right shit to do it with.:D
  11. Sep 14, 2008 at 12:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I should do mine, too, as much as Im in and out of the water, but I have been putting it off. :eek:
  12. Sep 14, 2008 at 12:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i especially wanna do mine before our next tacoma meet.....and we will probably do tigerfan's truck too.........as uwharrie has some good deep mud holes if it has been raining!!!
  13. Sep 14, 2008 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I need to do mine, 'cause when I launch my boat from a "beach", the water is up to the doors. Thats the noly time I really get the truck in the water. :eek:
  14. Sep 14, 2008 at 12:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....you definitely need to do yours, especially since you have an lsd.
  15. Sep 14, 2008 at 5:19 PM
    #35
    jrukus
    jrukus [OP] jason r
    Whats the deal with the LSD rear end anyways? Do you use different diff oil than 80w90? Any advantages or dis advantages? thanks.
  16. Sep 14, 2008 at 5:27 PM
    #36
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the lsd diffs have clutch packs that are very sensitive, and they require an oil with a limited slip addative. on an open diff/or diff with a locker.........regular 80w90 is fine.....on my 04 with the rear locker....i use mobil1 75w90 synthetic, and i like it alot. you dont need addatives/friction modifiers with an open diff like you do with a limited slip diff.
  17. Sep 14, 2008 at 5:39 PM
    #37
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    So on the 05+ the rear diff and tranny should be extended? And then you're good to have fun in the water?
  18. Sep 14, 2008 at 5:59 PM
    #38
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, and also, if you have 4 wheel drive.....the transfer case vent may need to be extended also.
  19. Sep 14, 2008 at 6:53 PM
    #39
    311offroad
    Milledgeville, GA
    Well damn, I was hoping it was only going to be the rear. How much do you estimate this will cost doing all three... and estimated time it will take to do it.
  20. Sep 14, 2008 at 6:55 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Me thinks the transfer case is already extended. There are 2 breathers in the engine compartment on the driver side. One is for the front diff, and the other is the transfer case breather.
