Necessary to plug rear differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 14, 2012.
  1. Jan 14, 2012 at 12:39 PM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Is it necessary to plug the rear differential fill hole to let the fluid run down the axle shafts? I just did mine: I filled it. When I started seeping I walked away for about 5 minutes. Came back and filled it again. It seeped. I left for like an additional 5 minutes and when I came back it was at a VERY slow run coming out the fill hole. Is this fine? I didn't plug the fill hole after each time either....
  2. Jan 14, 2012 at 12:43 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    how many quarts of gear oil did you use...anything over 3 quarts is too much.
  3. Jan 14, 2012 at 12:50 PM
    jeremy_283
    I got it on perfectly level ground and just filled it up to the fill plug. I heard from others that-that was all I needed to do. I don't measure cause it's never right cause I make such a mess doing everything.
  4. Jan 14, 2012 at 1:16 PM
    MonkeyProof
    SoCal- SGV
    if you filled the diff up to the fill hole with gear oil then you did it correctly :thumbsup:
