Necessary to use double prong spark plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chiz, Mar 2, 2017.
  1. Mar 2, 2017 at 6:09 AM
    chiz
    chiz [OP] Well-Known Member
    La Plata, MD
    2004 PreRunner
    I was changing my spark plugs yesterday and noticed there is a sticker that states that I have to use the double prong spark plugs and not the single pronged plugs. is this a true statement? what is the benefit of the dual pronged ones? TIA
  2. Mar 2, 2017 at 6:28 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    not mandatory, just what is recommended. I used single electrode for years when I switched the first time. then when I started tracing my idle issues switched back to dual-electrode
    here's a post regarding this. also if you do go single, make sure the gap is correct, I believe it's .44?
  3. Mar 2, 2017 at 6:43 AM
    chiz
    La Plata, MD
    2004 PreRunner
    Thanks for the info. I am going to go to the dealership and just get the oem double pronged ones. I am also replacing my wires. Thanks again.
    skeezix likes this.
  4. Mar 2, 2017 at 7:34 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I used a single electrode copper core plug in my truck but it's for a turbo application. Single prong absolutely works fine. The reason dual electrode is used is because the 5vz uses a "wasted spark" ignition system. 1 coil fires 2 cylinders at the same time, so spark plugs will actually fire twice as much as a distributor system or a engine with 1 coil pack per cylinder. The dual electrode lets them live longer. I had a truck that had the original dual electrode plugs in it at 240k miles believe it or not.
  5. Mar 2, 2017 at 7:34 AM
    Indy
    Indy Master of all I survey.
    Cheaper usually to get them elsewhere.
  6. Mar 2, 2017 at 9:53 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah, go to the auto parts store near you. I think I got all 6 for <$20 (~$3 a piece)
  7. Mar 2, 2017 at 12:01 PM
    chiz
    La Plata, MD
    2004 PreRunner
    I got them from the dealership for 2.75ish a piece. Out the door was 17 bucks but also got 10% military off.
