ned help installing alarm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by montgomery_30824, Jun 15, 2009.
  1. Jun 15, 2009 at 3:33 PM
    montgomery_30824
    montgomery_30824 [OP] Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    help!! i am getting an UNGO SR6000 alarm for my taco and i havent the faintest clue on where to begin. i started lookin through the wiring manual for my truck and its like looking at japanese. i have been doing avionics for almost 10 years now and can wire up anything on an aircraft or helo but i havent a clue what the heck those symbols mean. can anyone help a brotha out???
  2. Jun 15, 2009 at 3:49 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Is the manual hosted somewhere online? I'm curious as I may want to put an alarm on my ride too, I aint got one, just the factory keyless entry.
  3. Jun 16, 2009 at 12:00 AM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    seriously? no one on here can help me out with the wiring diagrams and explain what the symbols mean?
  4. Jun 16, 2009 at 3:21 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    Wire/FunctionCM4200ColourLocation/DescriptionPolarity 12 VOLTS RED & RED/WHITE(CN1) White/blue Ignition switch harness + IGNITION GREEN (CN1) Blue/yellow Ignition switch harness + IGNITION 2 BLUE (CN1) Black/red Ignition switch harness + ACCESSORY WHITE (CN1) Runs with ignition wire STARTER YELLOW (CN1) Black/white Ignition switch harness + STARTER 2 RED/BLACK (CN2) + Relay Green/black Ignition switch harness + KEY SENSE Green/black Ignition switch - TACH SIGNAL YELLOW/BLACK (CN3) See notes [​IMG]On the 2.4L and the 2.7L engine, there are 2 coils on the left front of the engine. Use the BLACK/BLUE or BROWN/YELLOW for a 2 cylinder signal. On the 3.4L engine there is a coil per cylinder. Use the wire opposite from the BLACK/RED at any of the coils. With any of the engines you can also find a BLACK tach reference at pin-15 of the 26-pin connector on the ECM behind the glovebox. FUEL INJECTOR Opposite from Black/red At any injector on engine AC LOCK BLUE/BLACK (CN4) Blue/white In driver's kickpanel - UNLOCK BLUE (CN4) Green/black (double pulses) In driver's kickpanel - DOORPIN RED/WHITE(+) or RED(-) (CN3) SEE NOTES [​IMG]GREEN (driver's door), GREEN/WHITE (passenger door), YELLOW/GREEN (rear doors). All 3 wires are found in a 22-pin connector on the front of the fusepanel under the dash. Isolate with 1N4001 diodes if connecting together.
  5. Jun 16, 2009 at 5:45 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    uuhhhh..... can you clarify this for me?
  6. Jun 16, 2009 at 5:52 PM
    tonto340
    Gambrills, MD
  7. Jun 16, 2009 at 5:53 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
  8. Jun 16, 2009 at 5:57 PM
    Disorderly
    Disorderly Well-Known Member
    Hes telling you which wires to connect to your alarm inputs. The first half looks like its for a remote start kit, the second half is basic alarm function.
    Example:
    Lock output from the alarm box blue wire with black stripe goes to a blue wire with a white stripe in the drivers kickpanel.
    Unlock output from alarm box blue wire goes to green wire with black stripe in drivers kickpanel and requires a double pulse.
    Clear?
  9. Jun 16, 2009 at 5:59 PM
    montgomery_30824
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    uhhh. kinda? what's the double pulse?
  10. Jun 16, 2009 at 6:00 PM
    Disorderly
    Fancy way of saying the alarm box must send a 12v trigger over the unlock wire twice. Should be a programmable option on the alarm, check the book.
