Need 1 inch up front
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Dec 4, 2010.
  1. Dec 4, 2010 at 6:44 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Now Please Im not looking to get blasted here Im just asking a question, just tell me if you think this is a good Idea or a Bad Idea. I need 5/8 to an inch lift for my front wheels to stop rubbing the wheel wells when i turn, so I looked at the struts and there is close to an inch of the 3 studs sticking up, So my thought is what if I stick some washers under each stud to gain the lift I need. Theoretically thats the same as a lift kit is. Again just asking Good or Bad.
  2. Dec 4, 2010 at 6:45 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    bilstein 5100's.....sorry what was the question?
  3. Dec 4, 2010 at 6:57 AM
    TheBlarneyStone
    TheBlarneyStone Member
    That's what she said.
  4. Dec 4, 2010 at 6:59 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Boone, NC
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    damn beat me to it
  5. Dec 4, 2010 at 7:02 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    At least put proper spacers up there.
  6. Dec 4, 2010 at 7:03 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Your washer idea is no good. Your right in that it will likely accomplish your goal, but damn, I wouldnt want to drive the thing knowing my extra inch was half ass! The top plate needs to have full contact with the coil bucket in order to achive maximum functinality and safety.
  7. Dec 4, 2010 at 7:08 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    no washers man. bet bilstein 5100 and sent them at .85" you will gain about an inch in all the right places
  8. Dec 4, 2010 at 8:10 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    or if your on a budget two top plate spacers and longer studs. shouldnt be much, but if you wanted to upgrade the shock get some billies
  9. Dec 4, 2010 at 9:46 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Ok Thanks for the info Guys, like I said it was just a thought and at the time it seemed like a good idea.
  10. Dec 4, 2010 at 9:54 AM
    Flash1034
    Flash1034 Well-Known Member
    Southern California
    2003 SR5 TRD 4x4 Extracab 3.4 liter
    None
    Don't we all...
    Flash
