Need 2 bed bolts to add tie downs but they’re $15-30+ per!!?
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by milesvanren, Jun 13, 2023.
  1. Jun 13, 2023 at 4:01 PM
    milesvanren
    milesvanren [OP] Well-Known Member
    miles
    Lopatcong, NJ
    05 tacoma trd 4wd v6
    Step bars, custom bumper, winch
    Anyone have any extras?
  2. Jun 13, 2023 at 4:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Is the perv free or at extra charge?
  3. Jun 13, 2023 at 4:22 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    It's $15 for the perv. $30 for no perv.
    3JOH22A[QUOTED] likes this.
  4. Jun 13, 2023 at 4:23 PM
    milesvanren
    miles
    Lopatcong, NJ
  5. Jun 13, 2023 at 4:41 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    From the other thread:
  6. Jun 13, 2023 at 4:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's a lot of work to add new bedbolts. You have to fab something to anchor them too.
    Why not use 2 existing bolts like everyone else? For free?
    VE7OSR and milesvanren[OP] like this.
  7. Jun 13, 2023 at 4:45 PM
    milesvanren
    miles
    Lopatcong, NJ
    I know but they’re frozen on, impact wrench won’t even, touch them so was thinking to cut them off & install new!
  8. Jun 13, 2023 at 4:49 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    *You can edit the title :thumbsup:
    milesvanren[OP] and boston23 like this.
  9. Jun 14, 2023 at 2:57 AM
    TacoTuesday1
    SD CA
    Expose it to heat and cold
    soak it with AeroKroil or similar
    clean the bolt head and firmly seat a high quality bit into it
    you say impact wrench
    do you mean a strong high quality one like IR 2235? with 1000ft lbs of torque connected to 100psi air supply?
    or POS Ryobi
    or, if you don't have compressed air, Milwaukee 1/2" M18 with a big battery might work.
    you mean i can't just glue on some tiedowns
  10. Jun 14, 2023 at 5:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Where are you planning to make the cut? The bolts are threaded into brackets on the frame. The bolts are long and thin, which is why an impact wrench can be ineffective.
    Suggest heating up the bolts and frame brackets from the underside with a torch to break up the rust and loctite, then loosen with a breaker bar. Use care when maneuvering the torch next to the fuel tank :)
    SR-71A likes this.
  11. Jun 14, 2023 at 5:44 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    This
    Plus start soaking the exposed bolt threads under the frame for all 6 bolts with PB several days in advance. Then heat. And use a big breaker bar with 1/2" drive T55 bit. Loosen, then tighten again, then loosen more, tight, loose etc.
    If you go ham with a big impact you will strip out either the bolt head or frame
  12. Jun 14, 2023 at 5:45 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Don't be a hater. My 1/2" Ryobi impact does 1170 ft/lbs for less money.
    EDIT: Also Ryobi Day Sale is on right now.
    SR-71A likes this.
  13. Jun 14, 2023 at 5:45 AM
    andagi808
    andagi808 Well-Known Member
    Hawaii
    2021 Black Tacoma TRD OR MT
    medium size pipe wrench worked for me, have you given that a shot?
    Slashaar likes this.
  14. Jun 17, 2023 at 5:11 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Try the old fashion impact you hit with a hammer, it has worked for me when nothing else will.
    Bagman likes this.
