Need 4.10 Third Member for 5Lug
Discussion in '5 Lug' started by carattini, Sep 6, 2011.
  1. Sep 6, 2011 at 9:33 AM
    carattini
    carattini [OP] Well-Known Member
    David
    Puerto Rico
    08 base model
    Hi I have a 2008 Access Cab Base model 2WD 5 Lug. I put some 29" Tires and need to swap third member for a 4.10. Does anybody has one for sale? :confused:
  2. Sep 6, 2011 at 10:21 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    best place to look is on ebay. non e locker rear ends from other tacomas will work
  3. Sep 6, 2011 at 11:53 AM
    carattini
    David
    Puerto Rico
    08 base model
    is my dif 7.5" or 8"?
  4. Sep 6, 2011 at 11:57 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    8.4" you need a 3rd member from 96+ Tacoma without the elocker. Elocker 3rd is 8" yours is 8.4".
  5. Sep 6, 2011 at 12:18 PM
    carattini
    David
    Puerto Rico
    08 base model
    Thanks for the reply. Can you tell me how you know that? is their any reference where I can find that out? Or is for personal experience?:eek:
  6. Sep 6, 2011 at 12:38 PM
    05RedTaco
    Tony
    Scottsdale
  7. Sep 6, 2011 at 2:04 PM
    carattini
    David
    Puerto Rico
    08 base model
    Thanks for the link but I'm confuse.
    It said
    "All 2wd and 4wd T100's, '00-06 Tundra's, and ??
    Sequoia's use a newer/stronger 8" 2-pinion diff.
    Tacoma 4x4's and Tacoma PreRunner's that don't come with the electric locker (aka "non-TRD), as well as V6 Tacoma 4x2's also came with this diff. "
    Min is not 4X4, V6, Prerunner
    It also said "This diff is NOT swappable with V6, 4cyl, high-pinion, or electric locking diffs"
    Min is 4Cyl but not shure about high-pinion.
    What do you think?
  8. Sep 6, 2011 at 9:40 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The V6, 4cyl, and high pinion diffs are on earlier toyota trucks/tacomas. What you have is commonly referred to as the T100/Tacoma 8.4" differential. Also known as non-TRD or non-elocker.
  9. Sep 7, 2011 at 8:39 AM
    carattini
    David
    Puerto Rico
    08 base model
    Thanks for the info so my Tacoma 5Lug (The small one) has the 8" Diff? so I can swap from any 8" diff no locker?
  10. Sep 7, 2011 at 9:36 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    no, the tacomas with the E-locker mainly 6 lugs have the 8" diff. I have a 2nd gen 5 lug and i'm trying to find the 8.4" ring and pinion set for cheap. thats what works
