Need 5100 Write-up with pics
Discussion in 'Suspension' started by WaGood24, Jul 25, 2011.
  1. Jul 25, 2011 at 8:14 AM
    WaGood24
    WaGood24 [OP] Well-Known Member
    Michael
    Dayton, OH
    2010 Double Cab PreRunner TRD Sport
    Extang Full Tilt tonneau, VX Series Exhaust, Nitto Terra Grapplers, Stainless Nerf Bars, Bilstein 5100s all 4 corners, rear-leaf TSB
    Can somebody please help me find a 5100 install write-up with pictures? The only write-up I can find is the sticky with the pics removed, and one other write-up with no pics attached. I've been looking but can't seem to find it. Thanks!
  2. Jul 25, 2011 at 8:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I used this one and found it helpful. The only thing it doesn't show is compressing the springs and swapping the stock coil from the old strut to the new strut.
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
  3. Jul 25, 2011 at 10:00 AM
    WaGood24
    Michael
    Dayton, OH
    Are there any specific to 5100s? Also, is it difficult compressing the springs? Do you need a special tool for that or will I just sit on it? Just kidding I won't sit on it.
  4. Jul 25, 2011 at 10:01 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah go to auto zone and rent a spring compresser:)
  5. Jul 25, 2011 at 10:02 AM
    Pugga
    Massachusetts
    You could sit on it, if you weigh over 1,000 lbs it might work but good luck getting the tops on :)
    You need a spring compressor. Check either Advanced Auto or Autozone, one of them rents tools out so you don't have to buy one. Compressing the spring isn't overly hard but it certainly helps having air tools. The install thread specific to 5100's was the one you found, the pics are missing. Installing a front strut is the same whether it's an OME or Bilstein though.
  6. Jul 25, 2011 at 10:22 AM
    WaGood24
    Michael
    Dayton, OH
    Ok, thanks for the help guys.
