Need 96 4wd or ignition wiring diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by IDtrucks, May 11, 2013.
  1. May 11, 2013 at 1:45 PM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I need to know which color wire and where the 4wd 15 amp line is, or the "run" ignition power line.
