Need a 4 wheel drive lesson and when to use what
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jk70, Oct 20, 2015.
  1. Oct 20, 2015 at 8:08 PM
    hurtcoastie
    hurtcoastie Well-Known Member
    Jordan
    2013 Regular Cab 4x4, MT
    I took my stock '15 DC OR to Uwharrie earlier this summer. No problems on the easy trail (why is there only one?). I proceeded to the next trail and kept scraping my exhaust pipe up front at the crest of almost every hill. I didn't like that so I turned around. I've got a decent lift now so I'll try again some other time.
  2. Oct 20, 2015 at 8:14 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    80, but the manual says 60 :anonymous: I know I know..
  3. Oct 20, 2015 at 8:18 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I know, I attempted humor/
  4. Oct 20, 2015 at 8:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Fucking Canadians
    Thanks for the conversion to Freedom Units though
    Jazz1one likes this.
  5. Oct 20, 2015 at 8:27 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  6. Oct 20, 2015 at 8:35 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
  7. Oct 20, 2015 at 8:44 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    4wd in redneck terms---- "if yur tyres start a spinnin put er in 4 wheel dig."
    I don't know why everyone is trying to put science into this.. :notsure::mudding:
  8. Oct 21, 2015 at 5:54 AM
    jk70
    jk70 [OP] My Mid-Life Crisis
    The Triangle, North Carolina
    Speaking of Uwharrie. Has anyone done the class http://www.uortc.com/ I certainly could use some tips and lessons and I certainly want to go first with just the stock vehicle. I don't know how much off roading I will do in the future so just want to start simple and get the basics down. Would hate to mod the car too much to find out I don't do it as much as I think.
    Also, any trails for riding in the triangle area; nothing too crazy, that I could just take the taco and get it "warmed" up? I was out at Table Rock off the Blue Ridge Parkway and although it was ~20 miles of dirt road there was no reason to engage 4wd. Don't know if anyone knows any long dirt roads that may get muddy in rain to have some fun at. I've looked up areas in Pittsboro but nothing came up
  9. Oct 21, 2015 at 5:57 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    There's really not much if any in the way of legal trails around. Your best bet is to find someone that owns land and will let you tear it up. Or just go to URE, it's $5 for a day pass or like $30 for a season pass. The best way to learn is just get out and do it.
  10. Oct 21, 2015 at 5:45 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Find a local club or some local TW Members who are willing to go to a local spot and show you a few things. Always nice to have others to help you out in the beginning. As to 4wd on pavement, as long as you don't get stupid with the skinny pedal it should be fine, just causes tire scrub and such. Most of our local wheeling is on dry granite so if it was going to hurt things, all of our rigs would be toast. Worst case scenario is full steering wheel lock, trying to turn..it will do it, but if you get stupid you can break things. One other thing, if you are pulling someone out of a "stuck situation" try to be driving forward when you do it. Backing up to extract someone is a good way to stress and break front end parts.
  11. Oct 21, 2015 at 6:25 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I pretty much agree. A lot of people here have way more off roading miles than I do, so I can only speak from my own experience. Rather than trying to map out possible situations to 4x4 settings, you're better off understanding what the 4x4 settings do. There's a post here by a member (Dave, IIRC) that does an awesome job of describing what the different modes are and what they do. Once you understand that, you'll know when to use A-TRAC and when to lock the rear. Dave also goes over which traction control systems limit engine output and which ones don't. That's good to know when you're in a "need momentum" or "need to spin the tires to clear them" situation.
    I've used DAC on a rocky decline...scary as SH*T. You gotta trust the truck a whole lot to push the button and then take your foot off the brake.
  12. Oct 21, 2015 at 7:16 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    @David K #atrac
    jtweezy and David K like this.
  13. Oct 21, 2015 at 7:19 PM
    OZ-T
    Peter North
    British Columbia
    #therewillneverbeadclbtrdoffroad
  14. Oct 21, 2015 at 7:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    In the winter the roads constantly go from snow covered to bare pavement, I put it in 4 High and go, never had any issues, as mentioned above the diffs are not made of glass.
  15. Oct 21, 2015 at 9:49 PM
    #35
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes? How can I be of assistance? Did someone say "A-TRAC" or "David K", THREE TIMES out loud?
    The link I think one is seeking about traction controls is in my signature >>>
    DrFunker and PSU Taco85 like this.
  16. Oct 21, 2015 at 9:50 PM
    #36
    David K
    That was two, close enough... thank you! Link in my sig.
  17. Oct 21, 2015 at 10:43 PM
    #37
    David K
    You know, that link in my sig covers up to 2011 drive modes. 9 wasn't enough for Toyota, so they added a 10th... Here are the 10 drive modes for 2012+ Tacoma Off Road 4X4s:
    The link in my thread on the traction choices covers to 2011. In 2012, Toyota added another drive mode to the 4WD Tacomas... in H4: 'TRAC OFF' choice instead on standard... and the standard mode in H4 is the new TRAC which has engine output regulation (as it always has in H2). Here is my thread on the newer modes: https://www.tacomaworld.com/threads/traction-controls-2009-2014.310726/
    HERE is the 2012+ data:
    2012 + (chages in bold)
    Press Nothing...
    H2= TRAC (Limited Slip with Engine Output Regulation)
    H4= TRAC (Limited Slip with Engine Output Regulation, front and rear)
    L4= No Traction Control
    Quick Press (VSC OFF SWITCH) moving or stopped...
    H2= AUTO LSD (Limited Slip without Engine Output Regulation, VSC OFF to 30 mph)
    H4= TRAC OFF (Limited Slip without Engine Output Regulation)
    Press and Hold In 3-5 seconds (VSC OFF SWITCH) while stopped...
    H2= VSC OFF (No Traction Control)
    H4= VSC OFF (No Traction Control)
    Off Road TRD:
    Quick Press of RR Lock Switch= Rear differential Locker (L4 only on 4WD models)
    L4 Only: Quick Press of A-TRAC Switch= Front and Rear near-no slip traction control. A-TRAC works the front below 3 mph when the Rear Locker is also on.
    What should you use?
    Standard Mode until you lose traction, then quickly press the VSC OFF button to increase the power of your traction control (more engine RPM, stronger braking on the spinning tires).
    In L4 (Low Range) and your tires spin, press the A-TRAC button (Off Road TRD only) to nearly lock-up any spin. I always have A-TRAC on in L4... unless you need to spin the mud out of the tires.
    Emergency stuck if A-TRAC doesn't work in any situation, press the RR Lock button (works with or without A-TRAC working on the front tires). The rear locker connects both rear tires from inside the differential (0 spin). Turn off RR Locker, once you are unstuck.
    1) H2 TRAC
    2) H2 AUTO LSD (VSC OFF to 30 mph)
    3) H2 VSC OFF
    4) H4 TRAC
    5) H4 TRAC OFF
    6) H4 VSC OFF
    7) L4 VSC OFF
    8) L4 & A-TRAC
    9) L4 & Rear Locker
    10) L4 & Rear Locker & A-TRAC
    1R0NMAN811 likes this.
  18. Oct 22, 2015 at 6:38 AM
    #38
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    That's it, thanks!
  19. Oct 22, 2015 at 7:39 AM
    #39
    acmccart8
    acmccart8 Well-Known Member
    NC
    2014 Limited Magnetic Grey DCSB
    Hey OP, I bought my first 4x4 (and truck in general) back in July, a 2014 DCSB Limited. I had all the same questions you did I just didn't get around to asking them since it is still MTB season so I am busy preparing for races. I live in the triangle as well, if you end up doing a class or going to a get together, hit me up. I would love to go to a Uwharrie class with someone who has as little experience as me! Sounds like your off-road would be miles ahead of my limited's suspension, so at least you won't have the worst truck out there.
  20. Oct 22, 2015 at 7:41 AM
    #40
    Sandman614
    Tim
    '06 SR5 Off Road
    @acmccart8 and @jk70 I'll keep both of you in mind for ure trips. :gossip: thanksgiving weekend I have a group going.
