Need a 8" lift....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hipespipes, Apr 3, 2013.
  1. Apr 3, 2013 at 8:18 AM
    Hipespipes
    Hipespipes [OP] Active Member
    Steven
    Modesto CA
    Stock for now
    Does anybody make a 8" lift? If so whats the price? Sorry guys its a 2013 dc 4x4.
  2. Apr 3, 2013 at 8:24 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    You need to say what vehicle you want it for. Otherwise all we can do is suggest you Google it... which should have been your first step.
  3. Apr 3, 2013 at 8:27 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    6" DB lift, or if you are a prerunner you can get 8" with spindles I believe
  4. Apr 3, 2013 at 8:33 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Really the only way 8" is possible, would be by stacking multiple lifts....
    6" drop bracket lift + 2" leveling kit(spacers)
    6" drop bracket lift + 2 or 3" body lift
    6" drop bracket lift + 2.5 to 3" suspension lift (coils, shocks)
    and if you're 2 wheel drive there are even more options with spindle kits.
    Many options & brands are available to accomplish this. Many guys on here will discourage you from stacking lifts together but quite a few have done it.
    :rofl:
  5. Apr 3, 2013 at 8:35 AM
    Large
    Large Red
    I can already see this thread becoming a :crapstorm: so I guess I'll whip out the :popcorn:
  6. Apr 3, 2013 at 8:43 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    6" db kit with with ome 884 or 885 up front and custom rear springs
  7. Apr 3, 2013 at 8:44 AM
    Manwithoutaplan
    ID
    same here Brace yourself OP.
  8. Apr 3, 2013 at 10:16 AM
    Warputer
    2011 TRD Off Road
  9. Apr 3, 2013 at 10:18 AM
    Manwithoutaplan
    ID
  10. Apr 3, 2013 at 10:19 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Are the curbs really that tall where you are? 8" wow :eek:.. How about them CV angles?
  11. Apr 3, 2013 at 10:19 AM
    Manwithoutaplan
    ID
    they are made out of cement which was rock at one point.
  12. Apr 3, 2013 at 10:23 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    What's the Need for 8", Just need to show someone up that has a 6"? And really how bad would the CV angles be with that, if 4x4?
  13. Apr 3, 2013 at 10:24 AM
    Manwithoutaplan
    ID
    i know 6 inch lifts are point less but the cv angle would not be to bad. Because on the 6 inch the cv angles are stock level.
  14. Apr 3, 2013 at 10:31 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    So 8" would be the same as a 2" lift, as far as CVs are concerned?
  15. Apr 3, 2013 at 10:36 AM
    Manwithoutaplan
    ID
    i think so.
  16. Apr 3, 2013 at 10:37 AM
    vette6991
    vette6991 Well-Known Member
  17. Apr 3, 2013 at 10:38 AM
    Manwithoutaplan
    ID
    or this ^ then you would not have to worry about cvs :D.
  18. Apr 3, 2013 at 10:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Cement is a soft powder. If your curbs are made out of that, I wouldn't worry about a lift. Concrete, on the other hand, is a little more rigid :D
    Screw the CV's, what about the drive shafts. The CV's between the transfer case and the wheel bearing would be similar to a truck with a 2" lift. The shaft between the transfer case and the differentials would be operating at an angle I'm sure it wouldn't be happy about and that's assuming the stock shafts even have enough play to allow that much lift (which I doubt that they do). The rear would likely require a drive shaft spacer or a new shaft altogether.
    I have to ask, why does one NEED 8" of lift?
  19. Apr 3, 2013 at 10:56 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
  20. Apr 3, 2013 at 11:01 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
