Need a good alarm system for a 2004 Tacoma that's under a 100 dollars
Discussion in '1st Gen. Tacomas (1995-2004)' started by Calitaclady, Feb 13, 2024.
  1. Feb 13, 2024 at 5:34 PM
    Calitaclady
    Calitaclady [OP] New Member
    Vivian
    2004 white Tacoma TRD
    None
    Looking for a good alarm system for my 2004 Tacoma don't want to spend over a hundred dollars, just a basic motion type alarm that's loud enough to hear if I'm indoors
  2. Feb 13, 2024 at 5:46 PM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    Does not exist.
  3. Feb 14, 2024 at 4:02 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    your '04 should have the factory RS3200 system already installed (if you have electric locking doors), just not "activated" if you buy a toyota security light + microphone, compatible remote (aftermarket works fine) and do some very simple modification to the wire harness (unplug ONE wire), you will have a pretty darn good alarm system that you can tune to your satisfaction (hard or easy to set off) for $40 or so
  4. Feb 14, 2024 at 6:41 AM
    Madjik_Man
    Colorado Front Range
    I know I’ve seen the wiring explanation but in that TW post that shows the harness unplugged the link to CustomTacos is broken.
    I have an 04 with the RS3200 and I was able to source an OEM glass break sensor.
    Just looking to complete everything.
  5. Feb 14, 2024 at 9:43 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    correct you unplug the ground to activate the alarm, its bundled in the RS3200 harness under the steering column, its a 1 pin connector.
    the OEM GBS come in 3 or 4 variants that all work, (camry, avalon, land cruiser, etc) , just the print on the face plate is different and the mic/light have 2x2 pin or 1x4pin, relatively recently someone posted the wiring for 2x2 to 1x4, I don't have time to dig for it today, plz search
    Edit, I searched. this thread has it all
    Madjik_Man[QUOTED] likes this.
  6. Feb 14, 2024 at 12:26 PM
    Madjik_Man
    Thank you. I’ll check it out when I have a moment.
  7. Feb 14, 2024 at 12:32 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    A manual transmission.
    You can make a kill switch for the starter battery or the fuel pump.
    JJ04TACO likes this.
