Need A Good Recovery Strap
Discussion in 'Off-Roading & Trails' started by Johns Taco, Nov 23, 2011.
  1. Nov 23, 2011 at 3:39 PM
    Johns Taco
    Johns Taco [OP] I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Iv'e been looking at the Mac's 27,000lb strap but wanted to ask what are people here using without breaking, before I order anything.
  2. Nov 23, 2011 at 3:40 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i always go with the most expensive thing (ie strongest) from tractor supply i can afford with NO HOOKS. loops are the way to go.
  3. Nov 23, 2011 at 3:40 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I use an ARB strap from Sierra Expeditions (which incidentally is a Vendor here and is having a sale this weekend)
  4. Nov 23, 2011 at 4:36 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Those Gray ones are sweet. They have an extra abrasion resistant webbing on the edges.
  5. Nov 23, 2011 at 4:39 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    4 wheel parts I just went today and I got 3 in by 30 ft tow strap rated 30000 for 25 bucks
  6. Nov 23, 2011 at 4:43 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I have two ARB Snatch Straps that are pretty awesome - you just have to watch the rebound.
    Fink
  7. Nov 23, 2011 at 4:53 PM
    Johns Taco
    Albuquerque, NM
    Thanks for the comments. Just picked up a 3 1/4" ARB, that thing looked so nice I had to buy it. It was expensive, lol. :)
  8. Nov 23, 2011 at 5:31 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I am going with a wheelers 30' strap when I get around to it. They are made in the USA, which I appreciate!
  9. Nov 23, 2011 at 5:35 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
  10. Nov 23, 2011 at 5:48 PM
    qwertypepper
    qwertypepper Well-Known Member
    cam
    canada
    2011 TRD sport dclb
    Is there a difference between a "recovery" strap and a nylon web sling used for overhead lifting? do they stretch more? are they more elastic?
    The reason i ask is at work i can get these a good discount, as we go threw a lot of these. i think this may be cheaper than buying a name brand "recovery" strap.
  11. Nov 23, 2011 at 5:56 PM
    mint355
    mint355 Member
    Clint
    Alice Springs N.T
    07' Hilux
    -Engine- Safari Snorkel K&N Factory Replacement High Flow Air Filter DP Chip 3 Inch Custom High Flow Stainless Steel Exhaust System Dual Battery & Red Arc maintenance System Heavy Duty Clutch; 30% More Grab 140ltr LoneRanger Fuel Tank -Exterior- ARB Sahara Bar with Fog Lamps ARB Side Steps ARB Rear Step/Tow Bar ARB Smooth Canopy ARB Roof Basket ARB Gen3 Roof Top Tent (New) ARB RTT Annex (NEW) ARB Awning (NEW) Rhino Aero Roof Racks Front & Rear Micky Thompson Rims & Tyres 265/75/16 EFS HD Suspension Hella 4000 Chrome Spot Lights Custom Chrome Grill Wide Flares & Mud Flaps UHF Base Aerial Premium 9000lb BushRanger Winch Rack Mounts for Shovel 4 Fishing Rod Mounts 2 Spare Tyres Toyota Hood Protector -Interior- GME UHF Split Unit Pioneer DVD Head Unit Polk Speakers and Amp Reversing Camera Cruise Control Gray Wool Sheep Skin Seat Covers Front Gray Fitted Canvas Rear Seat Cover Gray Rubber Floor Mats Tinted Windows Black Widow Draw System & Frig
    Slings have no snatch ability at all.They are for lifting not recovery situations though you could use a lifting sling for a winch extension strap
  12. Nov 23, 2011 at 5:56 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Well, a good recovery strap will only run you $30-50, depending on length.
    But if you can get a strap for free, why not? Find out the breaking strength of the straps, they should be adequate for recovery. Most recovery straps have a breaking strength of about 25k lbs.
    Recovery straps are pretty static (dont stretch much). Dynamic straps are like snatch ropes, they stretch and aide in recovery, like a rubber band.
  13. Nov 23, 2011 at 6:08 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    you need a strap that is the correct weight for your truck. that strap stretches, and that saves a lot of wear and tear on your truck.
  14. Nov 23, 2011 at 7:54 PM
    qwertypepper
    cam
    canada
    2011 TRD sport dclb
    well i figured that the stretch would help. the slings we have a more than adequate for the weight of the vehicle. thanks for the input
  15. Nov 23, 2011 at 10:57 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I've got a couple of straps from wheelers. Used them lots. Work great!
  16. Nov 27, 2011 at 8:04 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Are these the straps that stretch and yank or just regular straps? If not, are the stretchy ones worth getting?
  17. Nov 27, 2011 at 8:09 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Yes you want a stretchy type strap for recoveries.
  18. Nov 27, 2011 at 8:21 PM
    x2468
    good. i want to hint to the GF that i want one for Xmas. I need to go to a retailers website and leave the page with a straps description up before she gets on the computer.
