Need a hitch, suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SR54x4, Mar 17, 2011.
  1. Mar 17, 2011 at 6:42 PM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    I want to add a hitch to my 2010 4x4 4cyl access cab. The primary reason is to use as a recovery point as I do not have a trailer to pull. Once I have it on there then there is always the potential for a time or two where I would pull a small utility or uhaul type trailer. Either way, any suggestions on brand or model? I want something that does not hang down low and would like only the actual receiver to be showing.
    Here are three that I am considering, but open to other suggestions.
    http://www.etrailer.com/hitch-2010_Toyota_Tacoma.htm
  2. Mar 20, 2011 at 5:51 PM
    SR54x4
    Mark
    Hudson Valley
    anyone?
  3. Mar 20, 2011 at 5:53 PM
    jeff b
    jeff b Well-Known Member
    Find a good fabricator local or on this site and have it made.
  4. Mar 20, 2011 at 7:39 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Junk yard
    on another tacoma
  5. Mar 20, 2011 at 7:45 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    i would get the biggest one you can get for your truck. even though you may not be pulling anything, you may be the one who will be getting pulled or towed out. i think that in that case it wouldnt hurt to go biggest. hope that makes sense to ya.
  6. Mar 20, 2011 at 7:47 PM
    Itlodot
    Itlodot Active Member
    South Central Nebraska
    Tacoma Access Cab 4x4
    I put the Curt on my 2010 AC. Took 30 minutes by myself, duck soup:D It does the job as I pull quite a bit (all kinds of trailers, livestock feeders etc.) The pics all look similar but I had wondered if the Hidden hitch brand would be tighter up fit - but absolutely no complaints with the Curt.
  7. Mar 20, 2011 at 8:04 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    If mostly all your using it for is for recovery while wheeling and light towing I might check out some of the vendors here that make replacement offroad bumpers with hitches and recovery points built right in. Might be worth it as the money you put towards the hitch pays for half the bumper/hitch combo.
    Both of these are killer.
    http://www.tacomaworld.com/forum/armor-tech-offroad/42419-armor-tech-offroad-product-line.html
    and
    http://www.tacomaworld.com/forum/re...8184-relentless-fab-05-rear-plate-bumper.html
    Just an other option for you. Good Luck
  8. Mar 20, 2011 at 8:14 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Buy a used OEM hitch from a forum member who has put an aftermarket bumper on.
