need a lil help
Discussion in 'Performance and Tuning' started by xrspeedway, May 8, 2010.
  1. May 8, 2010 at 9:56 AM
    xrspeedway
    xrspeedway [OP] Member
    Eric
    PERRIS CA
    Stock
    Currently
    ok this is my third time taking the X for the stupid 02 sensors bank 1 and bank 2 the replaced them twice already and my check engine light keeps popping up and it throws out the same codes the 02 sensors. what can cause the 02 sensors to toss out a code. my uncle said it can be my intake thats throwing them off. can some of u X gurus fill me on my its doing that cuz its making the burn alot fuel
  2. May 15, 2010 at 1:00 AM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    Did the CEL come on? What code, if any from the OBDII scanner?
  3. May 15, 2010 at 1:02 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Are the only codes pulled for the P2 sensors, or are there other codes also? Some of the readers I've seen will only show the last code, you have to force it to retrieve older stored codes.
  4. May 15, 2010 at 2:09 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    What specific codes are you getting?
    What aftermarket modifications do you have on the truck?
    G
  5. May 19, 2010 at 10:02 PM
    xrspeedway
    Eric
    PERRIS CA
    Stock
    Currently
    it throw bank1 sensor 1 low voltage and bank2 sensor 1 high voltage and i only have a intake
