Need a little help please rough idle sitting in driveway but fine at high speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reareahar, Apr 27, 2023.
  1. Apr 27, 2023 at 3:56 PM
    Reareahar
    Reareahar [OP] Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    Hi there everyone, my tacoma has thrown several codes
    P0300
    P0304
    P0306
    P0456
    0k first of all love my truck 2003 prerunner silver, but just recently it started idling rough, had it tuned up new plugs, wires, ignition coils. She ran like a champ here I am 5 days later and back to rough idle. My local mechanic wants to charge me again for another diagnostic test. Any ideas, I've also changed Evap canister, oxygen sensor. I'm at my wits end total miles is 213,000
  2. Apr 27, 2023 at 4:00 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Kinda sounds like a vacuum leak. If you have a code reader with live data, check fuel trim readings.
    treyus30 likes this.
  3. Apr 27, 2023 at 4:01 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    Have a code reader but I don't know how to do that.
  4. Apr 27, 2023 at 4:02 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    Also the mechanic is telling me it's possibly the ECM
  5. Apr 27, 2023 at 4:04 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    I just spent 2k getting my frame fixed
  6. Apr 27, 2023 at 4:18 PM
    Cauliflower Power
    Cauliflower Power Active Member
    2023 Tacoma TRD OR DCSB
    Does your rough idle include it going higher and lower? If so, consider cleaning your idler air control valve.
  7. Apr 27, 2023 at 4:46 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    It runs smooth as a kitten on highway. I start it up it idles rough, put it in gear and it's worse. Get going at high speed and really good. It's weird. I'll try that and also clean my throttle body. What's your thoughts on the ECM
    Cauliflower Power likes this.
  8. Apr 27, 2023 at 6:25 PM
    d33pt
    d33pt Well-Known Member
    Going at highway speeds probably just masks the problem. What are the current codes that it's displaying now? Your mechanic seems to be just throwing parts at it without diagnosing anything. I'd take it somewhere else.
  9. Apr 27, 2023 at 6:35 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Find a new mechanic.
  10. Apr 27, 2023 at 10:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Seems unlikely. The ECM is not a typical wear item.
    Reareahar[QUOTED][OP] likes this.
  11. Apr 28, 2023 at 6:31 AM
    Cauliflower Power
    Agree with the folks above, not seeing how ECM is playing into this.
    Reareahar[OP] likes this.
  12. Apr 28, 2023 at 12:02 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Agree with what everyone else is saying. Rule out smaller things before jumping to ECM. Also if your mechanic did this "tune-up", I'd check his work too. Or have the next guy check his work. He sounds kinda worthless tbh
  13. Apr 28, 2023 at 12:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Which engine?
  14. Apr 28, 2023 at 12:31 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    It's 3.4 the mechanic is definitely out for money. It just makes no sense after total tuneup it ram great for a week then went right back to running bad again. It's almost like it's running on 2 cylinders. The timing belt was also replaced a year ago. A friend mentioned possibly the igniter that tells the coils to fire. Someone had asked for my codes p0300 p0304 p0306 looked them up all are cylinder misfire codes. I'm at a loss everything is new plugs, wires, ignition coils
  15. Apr 28, 2023 at 12:45 PM
    Red_03Taco
    Jerad
    Again double check all of his work. Could be a wide range of things to include [but not limited to]: coil packs, plug wires, plugs, MAF sensor, TPS sensor, PCV valve, vacuum leak. Double checking his work, then moving to vacuum line checks seems the most prudent first step though. Good chance this swindler used cheap non-OEM coils, wires, and plugs, and perhaps they failed way prematurely, or he didn't even torque plugs/coil packs properly, or something to that effect.
  16. Apr 28, 2023 at 1:51 PM
    Cauliflower Power
    This. Valid point to run by your mech, did he use OEM parts in that tune up?
  17. Apr 28, 2023 at 1:53 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    Just made appt with another mechanic. He mentioned spark plugs what kind were they? They were NkG plugs because I asked. The wires and coils came from autozone. He suggested running diagnostic test because this dude probably never did. He was more worried about screaming at my wife for clearing the code even though she wrote them all down. After he saw that the light was off he wasn't interested in even driving it to see what we were talking about.
    Red_03Taco and Cauliflower Power like this.
  18. Apr 28, 2023 at 2:08 PM
    Reareahar
    Md
    Tacoma 03 prerunner
    V6 3.4
    Thanks for your posts cant get into new station until May 11th but I'll definitely update when I have some answers.
  19. Apr 28, 2023 at 2:14 PM
    Cauliflower Power
    Sorry it all happened. Keep us updated OP
  20. Apr 28, 2023 at 2:16 PM
    Chuy
    Lakeside, CA
    Silver Taco
