Need a little help with brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by PrerunnerVsix, Dec 13, 2019.
  1. Dec 13, 2019 at 12:53 PM
    PrerunnerVsix
    PrerunnerVsix [OP] Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    Hey guys, so my 2000 tacoma prerunner brakes really poorly. The two issues I’ve found are that the brakes grab really low on the pedal and also whenever slamming on the brakes they are super hard like there is no power assist however the power assist works fine whenever you press on the brakes slowly like a normal stop. Whenever I do panic stop its hard at first and then goes down, this is pretty scary when you have to stop asap. It feels like a cushion of air preventing the pedal from going down. Trying to fix it myself I’ve replaced the booster twice, replaced the master cylinder and also bled the fluid a few times. While diagnosing, I tried clamping the rear brake line to see if they grab higher and they do so Im assuming my rear drums need replacement or adjustment but that didn’t solve the air cushion feeling when pressing hard. Any ideas? Thanks in advance!!
  2. Dec 13, 2019 at 12:59 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    When bleeding the brakes, did you bleed the rear proportioning valve last? Also, are the adjustment mechanisms in the rear brakes operating freely?
    koditten likes this.
  3. Dec 13, 2019 at 1:03 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    No I bled the RR, RL, proportioning valve, FR, and then FL. I thought you go from furthest to closest to master cylinder. Yes the rear brakes work fine but they have a little bit of slack im assuming because of the higher pedal with the rear line clamped shut.
    CS_AR likes this.
  4. Dec 13, 2019 at 1:09 PM
    CS_AR
    Check out this post.
    https://www.tacomaworld.com/threads/brake-issues.637531/#post-21970266
  5. Dec 13, 2019 at 1:29 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    So I just bled the proportioning valve and It was steady stream with no bubbles
  6. Dec 13, 2019 at 1:31 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This is good to see and share. I'd always bled my brakes like OP is saying, from furthest to closest bleeder. I'm sure I've incorrectly shared that or typed it on here. Oops.
    So it looks like the principle of bleeding the furthest to the closest is still correct, just holding off on bleeding the LSPV until the 4 corners are done.
  7. Dec 13, 2019 at 1:33 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    adjust your drums to where there is a *slight* NOISE when turning the hub. There should be very little actual drag. This will help brake pedal feel.
    How are you bleeding your brakes?
    Wyoming09 and PrerunnerVsix[OP] like this.
  8. Dec 13, 2019 at 1:33 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    I also read a hard pedal could be caused by lack of vacuum but my engine seems to run fine, no apparent vacuum leaks or anything
  9. Dec 13, 2019 at 2:27 PM
    Glamisman
    Glamisman Well-Known Member
    with the motor off press on the brake pedal until it gets hard. With slight foot pressure on the brake pedal start the motor. the pedal should drop a little bit. take your foot off the brake pedal and shut the motor off. now press the brake pedal. you should get 1 1/2 to 2 pumps before the pedal gets firm.
    CS_AR likes this.
  10. Dec 13, 2019 at 2:34 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    I went outside and tried it right now. I got 1 pedal with the engine off, the second pump was pretty firm after the halfway where my brakes start to grab.
  11. Dec 13, 2019 at 2:35 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    Im thinking I should check vacuum with a gauge. It seems like the booster is working fine but the engine isn’t supplying enough vacuum?
