Need a little help with the winch guys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Isaiasgon, Feb 12, 2012.
  1. Feb 12, 2012 at 8:14 AM
    Isaiasgon
    Isaiasgon [OP] Well-Known Member
    GA
    2013 4x4 TRD Sport V6 DCLB
    So these saturday i installed a hidden winch behind my factory bumper, all is good except i am not sure if this is normal. When ever i engage my winch the lights on the cab flicker/go dimmer. I know i read a thread once about this same problem but i can't really find it. Is this normal or do i need a bigger battery?
  2. Feb 12, 2012 at 8:15 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Is your engine running?
    I run mine with it running to help out the battery.
  3. Feb 12, 2012 at 8:18 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Its normal. Winches draw a lot of power. If you have it just for safety and are going to use it 4-5 times a year I would just leave it be. If you are going to be using it every weekend you might want to upgrade the battery and the alternator.
    Just don't run it without the engine running. You can kill a battery in a minute or two with the engine off.
  4. Feb 12, 2012 at 8:18 AM
    Isaiasgon
    GA
    yea it is, but is the flickering normal?
  5. Feb 12, 2012 at 8:26 AM
    Isaiasgon
    GA
    Sweet sounds good, i plan to use it incase i get stuck on trails and if maybe i need it for emergencies, I guess for now i can upgrade the battery and see how things go. It still has the factory battery which i think that may be the problem then.
  6. Feb 12, 2012 at 8:38 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Anyone aware of an over-the-counter hidden winch (behind factory bumper) option for the 2012 Tacoma? Searching hard, but no success so far.
  7. Feb 12, 2012 at 1:51 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    I can't help with that, my dome light has been out for a long time and luckily I have only winched in the daytime, so I have not noticed any light flickering.
  8. Feb 12, 2012 at 2:40 PM
    Isaiasgon
    GA
    LOL Well i hope by me getting a bigger battery it will help some.
  9. Feb 12, 2012 at 2:42 PM
    Isaiasgon
    GA
    Try emailing the people from http://undercoverhwms.com/wp/
    they might be able to help some.
  10. Feb 12, 2012 at 5:10 PM
    stewartx
    Huntsville AL
    ^^ Someone in another thread said their mounts aren't compatible with the 2012 - their website hasn't been updated. Nevertheless, I'll email them to double check.
    UPDATE: Did not email to verify compatibility, so don't know if their mount is or isn't. Instead, I decided to simply order a front hitch from Curt and will be installing a winch using that.
  11. Feb 13, 2012 at 4:06 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Do you have the tow pkg?
  12. Feb 13, 2012 at 4:57 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Reason I ask,The alt. in the towing pkg.is 120 amps.and h/d batt.
  13. Feb 13, 2012 at 7:05 AM
    Utard
    Mark
    Nyssa, Oregon
    Its not really a big deal to have the lights dim. But just remember a winch draws a lot of amps. Even big or small battery I would try NOT to have the headlights and A/C and radio blasting at the same time I was winching. I would use the winch a few times before you upgrade the battery. I would think that battery will work just fine. Unless you are doing pulling out all the cable for full pulls every weekend it would be a waste to change batterys. I had a jeep with a small battery and winch and it was never an issue.
    If you are new to winching watch a few vids of people winching. A few things to get a tree strap so you do not kill trees. If you are using the cable line get a cable weight. Another good thing is a snatch block. A few D-rings for the straps.
  14. Feb 14, 2012 at 6:58 AM
    Isaiasgon
    GA
    Yes in do have the tow package
  15. Feb 14, 2012 at 7:01 AM
    Isaiasgon
    GA
    Ok thank you, that would definetly save me money for now, but I really do need to get all the recovery stuff soon.
