Need a little more drop..
Discussion in 'Lighting' started by ABA180, Jun 24, 2013.
  1. Jun 24, 2013 at 11:16 PM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Westin light bar with 2 PIAA 520 crystal ion fogs and 1 driving.
    I had the fogs only for a few weeks and no issues..since throwing the driving light on I keep getting high beamed, plus a talking to from the boys in blue *DOH!*
    The lights are as far down as I can get them on the bar. They go pretty much straight out but seem to go up a little as they go out.
    I'd like to keep the setup and be able to use it as often as possible. My thought is if I slide a washer or 2 in between bar and light, that should raise it a little and enable me to aim them down more at the road.
    Anyone tried this before? How did it go?
  2. Jun 25, 2013 at 8:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    A driving light is designed to be used when hi beams would be appropriate, meaning no oncoming traffic. If you need more low beam, look into an HID retrofit with projectors. There are plenty of posts on here about retrofits.
  3. Jun 25, 2013 at 9:42 PM
    ABA180
    East Bridgewater MA
    I've seen the retro jobs, not sure I want to spend the cash. I should explain that I was able to wait it out and find a couple of nice deals, both here and elsewhere, to put together my current setup.
    Another thought I had was maybe to convert the driving one to a fog (swap the lens) and have 3 fogs that at least wouldn't be so harsh on other drivers..
