Need a mechanic near Atlanta!
Discussion in 'Georgia' started by Braindead, Aug 27, 2016.
  1. Aug 27, 2016 at 9:23 AM
    Braindead
    Braindead [OP] Well-Known Member
    JoJo
    Atlanta
    02 PreRunner
    I have gathered ALL the parts (recommended on this forum) but my health has gone downhill and I need a skilled, experienced Toyota mechanic to do the labor. I found two guys in Atlanta and agreed to their ASKING prices. The first guy never showed and never returned calls. Today the second guy never showed after rescheduling twice.
    I live in Lilburn a suburb of Atlanta. My truck is a 2002 Prerunner, 2WD, auto, V6, all stock
    My email is info@GunnsPhotoVideo.com
    Thanks guys
  2. Aug 27, 2016 at 2:29 PM
    rodehard
    rodehard Active Member
    BKP
    2001 Tacoma Base
    K&N Intake. Gutted Cats. Slightly larger tires.
    You never said what you needed done.
  3. Aug 27, 2016 at 3:49 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Yes that might be a interesting fact to know
  4. Aug 27, 2016 at 3:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  5. Aug 27, 2016 at 5:16 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If its drive-able, take it to a nearby mechanic that specialized in Toyotas. That would be my suggestion.
  6. Aug 28, 2016 at 12:51 PM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    I bought all the parts because I planned on doing the work myself. Unfortunately, I busted three ribs and messed up my back pretty bad. I thought I would heal but things have only become worse. I did contact three garages but none would accept my parts. Even the stealorships declined. No way I will be able to sell all the parts and not lose too much.
    Here is my list:
    Fuel filter change….
    Coolant replacement and flush….
    Oxygen sensor replacement…..
    Catalytic converter replacement…..
    Struts/Shocks replacement…..
    Brake pads, drums, rotors replacement…..
    Brake fluid flush and replacement…..
    Valve cover gasket replacement.....???
    Head gasket replacement…..???
    Spark plugs replacement…..
    Differential oil replacement…..
    Carrier bearing replacement…..
    PVC valve replacement…..
    Power steering fluid replacement.....
  7. Aug 28, 2016 at 6:03 PM
    rodehard
    BKP
    2001 Tacoma Base
    Wow. That is a lot of work. If I were closer I'd definitely get the done for you. That's a big payday.
    wilcam47 likes this.
  8. Aug 28, 2016 at 6:11 PM
    koditten
    Kirk
    Central Michigan
    Have you checked Craigslist? There are always guys on there.
  9. Aug 29, 2016 at 3:56 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    That is where I got the last two no shows.
  10. Aug 29, 2016 at 3:56 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Where are you?
  11. Aug 29, 2016 at 5:25 AM
    rodehard
    BKP
    2001 Tacoma Base
    South Alabama
  12. Aug 29, 2016 at 5:44 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Why wouldn't they accept your parts?
    Afraid of sub-standard parts that they could not guarantee, or just a missed opportunity of profiting from their overpriced parts?
  13. Aug 29, 2016 at 5:48 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    They were afraid of my parts. I actually bought Toyota parts or upgrade parts from Rock Auto.
  14. Aug 29, 2016 at 5:49 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    How far are you from Atlanta?
  15. Aug 29, 2016 at 10:28 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Strange. My favorite mechanic actually requests that I bring my own parts...
  16. Aug 29, 2016 at 12:35 PM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    I just found a garage in Atlanta that said "No problem". I am waiting for a quote.
  17. Aug 29, 2016 at 1:10 PM
    islanti
    islanti Well-Known Member
    1998 Tacoma SR5 V6 4x4
    Get a quote on changing the PCV valve. Should give you a good idea of how out to lunch their pricing is since PCV valve is about as easy as an air filter to swap
  18. Aug 30, 2016 at 7:34 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Take a look!
    Joe,
    I have ALL the parts! They are either Toyota or better.
    JoJo
    On 8/29/2016 12:08 PM, joe@toyotechs.com wrote:
    I can not use your brake fluid or coolant in my machines as they are on loan from BG and its there policy to use only there fluids. I can drain and fill them if you want to use different fluid.
    Oxygen sensor replacement….. $150.00
    Catalytic converter.......... $300.00 WE PROVIDE PARTS
    Fuel filter change….. N/A "IN THE TANK"
    Coolant replacement and flush…..$120.00
    Brake pads, drums, rotors replacement…..$360.00 YOUR PARTS
    Brake fluid flush and replacement…..$135.00
    Valve cover gasket replacement.....$600.00
    Head gasket replacement…..$3000.00 WE PROVIDE PARTS
    Spark plugs replacement…..$100.00 WE PROVIDE PARTS
    Differential oil replacement…..$50.00 WE PROVIDE PARTS
    Carrier bearing replacement…..SUBLET TO DRIVE LINE SERVICE OF N.ATLANTA
    PVC valve replacement…..$20.00 WE PROVIDE PARTS
    This is for a 2002 Toyota Tacoma Prerunner, auto, 2WD, V6, 144K miles Xtra cab
    They decided they wanted to use their parts!
  19. Aug 30, 2016 at 7:49 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Daymn.
    Keep lookin.
    $20.00 to replace a PCV????
    $600.00 for valve cover gaskets???
    Run Far, Run Fast.
  20. Aug 30, 2016 at 8:51 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    That's highway robbery! I have an 04 Tacoma and I thought the fuel filter is below the driver's side door inside the frame rail. At least mine is. The fuel pump is in the gas tank. Complete rip off! They're definitely trying to take advantage of you!
    eon_blue likes this.
