Need a new amp for my Subs
Discussion in 'Audio & Video' started by TSmalls89, Mar 24, 2015.
  1. Mar 24, 2015 at 6:17 AM
    TSmalls89
    TSmalls89 [OP] Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    Pushing two Alpine Type R 10ts in a sealed box. Looking to get my hands on a beefy amp to run them. What would people recommend? Here are the specs for the subs:
    Features and Specification
    SPECIFICATIONS
    Power Handling
    CEA-2031 Power Rating: 600W
    Power Range: 300 - 600 Watts
    RMS Power Handling: 600W
    Peak Power Handling: 1800W
    Dimensions
    Mounting Depth: 82 mm (3.25'')
    Mounting Diameter: 231 mm (9.1'')
    Displacement: 0.07 cu. ft (Front Mount)
    Added Volume: 0.04 cu. ft. (Reverse Mount, Magnet Out)
    General
    Frequency Response: 28Hz - 200Hz
    What are good brands for amps? I want these subs to slam.
  2. Mar 24, 2015 at 7:12 AM
    ike3000
    ike3000 Well-Known Member
    I would go at least 1000W shared between them. Something like an Alpine PDX-M12 or JL HD1200/1. Both are compact and very capable of putting out good, clean sound.
  3. Mar 24, 2015 at 8:52 AM
    TSmalls89
    Tyler
    Merrimack NH
    I am currently running a Kenwood 9106D, but it keeps shutting off. Brand new piece of equipment, Rated 1000x1 @ 20hm (what I am running at currently) and after about 10 minutes it shuts off. Not getting hot at all, ground is perfect, all wires are clean.
  4. Mar 24, 2015 at 9:26 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    First, are you SURE you have the subs wired correctly to yield a 2ohm load? Have you verified this with a digital multimeter?
    Second, what are the enclosure specs? How big is the box internally?
    Third, let's try a test. You said the amp will shut off about 10 minutes after starting it. Is this while it is turned up very loud? Try playing it at a lower volume and see if it still shuts off after 10 min.
    My guess is you're clipping the hell out of the amp and or you're bottoming out the speakers.
  5. Mar 24, 2015 at 9:38 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    does the Red protect light come on, and Reset once u turn the ignition on and off ?
    Are you running at least a quality 4 gauge power and ground ? What is your voltage doing ?
    italynstylion mentioned it could be from clipping your amp Which it very much can be. What confuses me is that you mentioned it doesnt get hot at all.If your running a load that will make the amp shut down, 9/10 amps will get rather hot. I think your amp is shutting off because of to much voltage drop and the amp doesnt like it, or there something wrong with its power supply
  6. Mar 24, 2015 at 9:42 AM
    TSmalls89
    Tyler
    Merrimack NH
    Running 4 gauge through the truck, tested OHM with meter at speakers (properly wired and also tested them before getting to amp). Ran the subs at lowest power and still shut off. I did notice my remote wire isn't connected well at stereo so I plan to correct that this evening. Box ratings:
    (Vb) - Air Volume
    per Sub - cu. ft. - .85
    Mounting Depth - 10" - 5 7/8"
    Hole Openings - 2-10"
    Cut Out D - 9 1/8 for 10"
  7. Mar 25, 2015 at 7:16 AM
    TSmalls89
    Tyler
    Merrimack NH
    Bump, anyone else have any ideas? I am officially stumped
  8. Mar 25, 2015 at 9:16 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Amps power supply, or loose power/ground or a ground that's not making a proper connection. Measure the milliohms between the amp negative and the battery -post
  9. Mar 25, 2015 at 10:09 AM
    ike3000
    if your remote wire is losing +12V then the amp will shut off. does it consistently remain on for just 10 minutes or does the time vary? if it's pretty repeatable then it sounds like something is wrong with the amp internals. you may need to give a call to your shop or Kenwood.
  10. Mar 25, 2015 at 12:31 PM
    TSmalls89
    Tyler
    Merrimack NH
    It's been very repeatable the past week. Sometimes even if I shut the truck off, turn it back on the amp will shut off after the first hit.
  11. Mar 25, 2015 at 12:53 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    you can also test your remote turn on wire at the amp side of things. Put a 12v meter there and watch it while it plays/ turns on etc. if that drops, or cuts out you know its ur remote wire
  12. Mar 25, 2015 at 1:10 PM
    TSmalls89
    Tyler
    Merrimack NH
    I thought it was that so I replaced the entire wire last night. Ran a test for a few minutes and didn't see it flex at all (11.9v lowest)
  13. Mar 25, 2015 at 1:38 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Well if everything is " correct " as you say, then its the amp.
  14. Mar 25, 2015 at 1:43 PM
    Aw9d
    Aw9d That one guy
    If you plan on buying an amp for the alpines their PDX line works great with the Type-R subs. I have the 600w Mono PDX for my Type-R 12 and it powers the shit out of it. My gain is all the way down on the amp and -4 on my HU's sub outputs, still hits really good, really low, and really clean.
  15. Mar 26, 2015 at 9:43 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Call the manufacturer and let them know what you've tried. It sounds like you've done the proper tests. Not sure what else it would be.
  16. Mar 26, 2015 at 10:19 AM
    TSmalls89
    Tyler
    Merrimack NH
    Well did my final tests, amp is bad and I have decided to go a whole different route on the sound so I am returning the amp, selling the subs, and returning the box. Going to run a single 12 instead. Thanks for the help people.
  17. Mar 26, 2015 at 2:57 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Single 12 with good power behind it will be plenty. You likely won't have room for a ported box but it should still be enough sub for the cab of a Tacoma.
  18. Mar 26, 2015 at 6:02 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    With minor modifications there is a good 2.2 CF for ported 12 :) shhh ;)
