Need a off-road front bumper 05-11
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frincon75, Sep 9, 2017.
  1. Sep 9, 2017 at 12:35 AM
    Frincon75
    Frincon75 [OP] Active Member
    Frankie
    SoCal
    2008 Tacoma double cab
    Bilstein 5100s in front and flow master 40 series. 275-70-17 KO2s with pro comp series 41 phaser wheels
    I need a front bumper and some front coils or any cool parts in socal
  2. Sep 9, 2017 at 5:54 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    yah, me too. I'm thinking I would like to go aluminum.
  3. Sep 9, 2017 at 8:17 AM
    Pigpen
    Dan
    Northwest Montana
    I'm going with unobtaium
  4. Sep 9, 2017 at 9:15 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Not adamantium? Mythril? Vibranium?
  5. Sep 9, 2017 at 9:25 AM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    pelfreybilt fo sho! Aluminum or Steel.
  6. Sep 9, 2017 at 1:01 PM
    Pigpen
    Dan
    Northwest Montana
    Pelfrey hybrid FTW
