Need a pic of this lift please...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt45648, Mar 15, 2009.
  1. Mar 15, 2009 at 9:34 PM
    matt45648
    matt45648 [OP] Well-Known Member
    Im trying to decide on a lift... Iv been lookibg really hard at the front spacers and rear aal. Can someone post a pic of this lift? Just the lift (only whats in the kit), no other components. I believe its a 3" kit. Thanks!
  2. Mar 15, 2009 at 9:35 PM
    tjgraner09
    tjgraner09 South Carolina Member
    TJ
    Conway, SC
    97 XtraCab
    Bilstiein 5100 w/ TRD Coils in the front, new fog lights, 2 12" isignia subs,
    what year is your truck if it is a early 1st gen i have a set of coil spacers for sale
    http://www.tacomaworld.com/forum/buy-sell-trade/30378-97-tacoma-parts.html
  3. Mar 15, 2009 at 9:36 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  4. Mar 16, 2009 at 10:06 AM
    matt45648
  5. Mar 16, 2009 at 10:08 AM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    i thought you had a 99
  6. Mar 16, 2009 at 10:30 AM
    matt45648
    08 rugged trail
  7. Mar 16, 2009 at 10:56 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Not too many people have that lift. Thats because its not that great of a lift. Especially if you offroad. But there are a few people on here that have it. I cant recall who tho.
  8. Mar 16, 2009 at 11:07 AM
    matt45648
    I just dont want to spend a ton... Like 500... I just want it to look good. Most off roading I might do is some mud...
  9. Mar 16, 2009 at 11:10 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I just bought a week old OME setup for 550. You get the lift from the coils instead of the spacers. I have a friend that has the spacers and he hates it. Honestly i would save up a little bit more and get the OME 885 coils and front OME shocks. Do you have the rear tsb done?
  10. Mar 16, 2009 at 11:13 AM
    matt45648
    Rear tsb????
  11. Mar 16, 2009 at 11:15 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    you could get this...http://toyteclifts.com/index.php?pa...ategory_id=64&option=com_virtuemart&Itemid=53
    and these...http://toyteclifts.com/index.php?pa...ategory_id=64&option=com_virtuemart&Itemid=53
    I think you can run that front setup without adding rear shocks. You will have to double check on that. Then if the back sits too low just buy an aal. Also, your truck will already be lifted so just slowly save up for the rear OME shocks...http://toyteclifts.com/index.php?pa...ategory_id=64&option=com_virtuemart&Itemid=53
  12. Mar 16, 2009 at 11:16 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yes. You said you have an 08 right? me too. Did you buy your truck new? or is there a previous owner?
  13. Mar 16, 2009 at 11:21 AM
    matt45648
    I bought it new.
  14. Mar 16, 2009 at 11:35 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ok well basically right now your leaf pack only has 3 leaf springs. There is a Technical Service Bulletin (Hence TSB) to where the truck can bottom out under heavy loads and what not yaddy yaddy yadda. Theres lots of threads on here about that. Basically first check to make sure you only have 3 leafs on each side. Then go to the Toyota dealer and tell them that the truck is bottoming out whenn you put about 500lbs in the bed. You could just try sayig you want the tsb done. lol. It depends on the dealer. Some dealers will happily do it, while others are jerks. It's free too
  15. Mar 16, 2009 at 11:36 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    The new leaf pack will have 4 leafs instead of 3. And you will gain about and inch in the rear. Ive heard some people gain 1 1/2.
  16. Mar 16, 2009 at 11:46 AM
    matt45648
    Where is the tsb listed... Never got anything in the mail..
  17. Mar 16, 2009 at 11:58 AM
    matt45648
    Hrm, so how do I tell them I know about it?
  18. Mar 16, 2009 at 12:16 PM
    matt45648
    Just my atv
  19. Mar 16, 2009 at 2:02 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I was just trying to give the guy some insight on my experience since i have done the tsb. One day i took my truck in because I was hearing a noise from the front of my truck. The dealer said "Is your truck bottoming out on bumps when its loaded?" when he said this he was shaking his head yes for me to go along with it. The dealer actually wanted to do the tsb. I had no idea until then what it was. Therefore it depends on the dealer. They didnt even test drive it. They just took the keys and said it will be done later.
    The whole point is....this is a free new rear suspension from Toyota! There are many people on this site trying to get it done...but no longer can because their truck isn't under warranty.And since you use your truck to carry your atv....why not. I use mine for my cr250. Take advantage while you still can. Thats just my two cents. And i know many will agree.
    Also, Oakley is partly right. Toyota didnt create the suspension tsb to give people free lift. But it just happens to be that when you add a leaf...you will get more lift. Sure it will settle a bit but you should still get some lift in the back. This is also why toytec came out with the tsb aal.
    The whole point I was trying to make earlier is that when you buy your truck bone stock, the back is already a little higher than the front. Then if you get the tsb done, even if you only get 1/2" of lift in the back...the back is still higher. Therefore i was trying to state that its okay to get the front OME setup like we stated and dont buy or leave out the rear aal. Then install the front and see how level your truck is. Then go from there. I have the OME setup to install up front along with the rear OME shocks. I dint buy an aal yet. Im going to install what I have and then go from there and maybe buy an aal later. So I will keep you informed as to how it goes and supply you with pictures.
  20. Mar 16, 2009 at 2:30 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    i forgot to add that you get a free alignment too. So if you wanted to do the left...install it first, then go get the tsb done so get a free alignment. Just a thought.
