need a suspension expert
Discussion in '1st Gen. Tacomas (1995-2004)' started by coehorn1, Jan 14, 2011.
  1. Jan 14, 2011 at 10:30 AM
    coehorn1
    coehorn1 [OP] Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    My '03 truck frequently will not track a straight line. Three mechanics have looked at it. I've had new:
    1) shocks and struts
    2) swaybar bushings
    3) rank and pinion mechanism + bushings
    Tire pressures have been changed from Toyota recommended values all the way to 38 PSI.
    In heavy crosswind, it's a real struggle. Also, it wants to follow imperfections in the road surface. To me, it feels sloppy -- like ball joints.
    Other vehicles -- a Prius and S10, track fine. I've previously owned a pre-Tacoma Toy truck and a Camry.
    Suspension experts ..... I sure need your help. Where should I look to put this nonsense to bed once and for all?
  2. Jan 14, 2011 at 11:15 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    what's your alignment specs look like? ..have your camber and toe checked.
  3. Jan 14, 2011 at 11:30 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    is it pulling a certain direction?
  4. Jan 14, 2011 at 11:59 AM
    coehorn1
    It's been aligned 3 or 4 times now. I did not ask for the specs. The last time, the mechanic said he checked the real wheel alignment too.
    Is there a slot in the specs that's known for being "right"?
  5. Jan 14, 2011 at 12:03 PM
    coehorn1
    It seems to follow road defects or slope. When it starts to wander, I have to counter steer just slightly until it starts to respond. Like there's some slop in the linkage somewhere.
    Sorry, but I don't know the proper terminology.
  6. Jan 14, 2011 at 12:08 PM
    PLC721
    Patrick
    Chandler, Az
    you might have answered your own question, your steering shaft might be loose?
  7. Jan 14, 2011 at 12:09 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Has the truck been in an accident and when repaired is it dog trailing meaning, standing behind the truck 20 -25 ft look at the back wheels,are they in alignment with the front wheels.
  8. Jan 14, 2011 at 12:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    FYI - Every Toyota truck I have owned acts like a sailboat in crosswind.
  9. Jan 14, 2011 at 12:12 PM
    PLC721
    Patrick
    Chandler, Az
    yes thats true
  10. Jan 14, 2011 at 12:12 PM
    coehorn1
    I'll have it checked. Thanks.
  11. Jan 14, 2011 at 12:13 PM
    coehorn1
    I picked up the truck with 35K miles. No dirt on carfax and the truck has been examined by lots of mechanics. But who knows what has really happened in the used-truck crapshoot?
    I'll get someone to follow me and check it. Thanks.
  12. Jan 14, 2011 at 12:24 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    What tires are you running?
  13. Jan 14, 2011 at 12:45 PM
    coehorn1
    Dunlop A/T Radial Rover
    P26570R16
    They were new on the truck when I picked it up.
  14. Jan 14, 2011 at 12:48 PM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Ditto, my truck wanders. As far as I know this is perfectly normal for 1st gen tacos.
  15. Jan 14, 2011 at 12:51 PM
    mjp2
    NJ
    Reviews on TireRack list various pros and cons but nothing about highway wandering. Some tires with soft sidewalls or bias plies tend to follow grooved in the road like you describe so I thought that might be the issue.
    The search continues...
  16. Jan 14, 2011 at 3:57 PM
    coehorn1
    Nice site.
    What tires do people put on these 1st gen 4x4's? I need tires for slow and easy off road maybe 5% of the time. Other than that, need a quiet highway tire for mileage.
  17. Jan 14, 2011 at 6:19 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    44" Pitbull Rockers :D
  18. Jan 14, 2011 at 6:39 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    I wish you the best in figuring this out....I know how annoying it can be, I actually sold my last truck (03 Tundra) because of this exact problem. Spent probably $4000 trying to fix it; tires, steering, suspension, the whole nine yards. Let us know!
    To the other guys that say its normal....the 03 Taco I picked up feels rock solid and drives true compared to that Tundra...just fyi
  19. Jan 14, 2011 at 6:40 PM
    NegroTundra
    Land of Enchantment
    Michelin LTX M/S
  20. Jan 14, 2011 at 8:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO the "in spec" numbers are way to lax. Then there are the inexperienced techs using the equipment.
    Toe should be 0*, camber should be 0*, and most importantly, regarding highway wander, the caster should be higher than 2.0*. Ideally, the caster should be 2.5-3*.
    I think you need to take a closer look at the actual results of the alignments.
