need a wallet friendly 33x12.50R17 tires(4)
Discussion in 'Wheels & Tires' started by jt05tacoma, Jan 10, 2012.
  1. Jan 10, 2012 at 7:44 PM
    jt05tacoma
    jt05tacoma [OP] Member
    jackson
    eatonton, ga
    black '05 sr5
    steelcraft bullbar, 4x4 3rd tail light, removed mud flaps
    trying to getthe max hight out of my taco without changing my stock rims. with 3" procomp lift
  2. Jan 10, 2012 at 7:49 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    You will rub your uca, you have to buy spacers
  3. Jan 10, 2012 at 7:57 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Just get a 285/70/17. Its 33x11.5 so its just a little skinnier but you will still need a wheel spacer on the stock rims.
  4. Jan 10, 2012 at 7:59 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    check out treadwright.com for some cool tires for cheap. They have really good reviews and there is a big thread on here about them.
  5. Jan 10, 2012 at 8:02 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
  6. Jan 10, 2012 at 8:06 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I am running treadwrights also. Great tires.
  7. Jan 10, 2012 at 8:09 PM
    RenoTacoma
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Just curious but What mileage are you getting with those 285s? :spy:
  8. Jan 10, 2012 at 8:19 PM
    nfs257
    Im not sure because the odometer and speedometer are both off. But im showing anywhere between 13 & 19.
  9. Jan 11, 2012 at 1:15 PM
    jt05tacoma
    jackson
    eatonton, ga
    black '05 sr5
    the only reason i gave those mesurements is because procomp said that was the max size with this lift.
