Need a340e transmission in Portland, Or Area
Discussion in 'North West' started by fixingseanpdx, Sep 16, 2021.
  1. Oct 2, 2021 at 7:15 PM
    fixingseanpdx
    fixingseanpdx [OP] Active Member
    Portland, Or
    2003 Tacoma v6 Prerunner
    Thanks for your help, I'll scan my truck tonight and report back tomorrow.
    gearcruncher likes this.
  2. Oct 3, 2021 at 7:45 AM
    fixingseanpdx
    Portland, Or
    Hey gearcruncher, so I scanned for codes and nothing showed up and no check engine light either. I also rev the engine to about 5000rpm with the hood up and I saw no shaking at all.
    But, I forget to mention that on a cold start once I back my truck up and put it in drive and press the gas I hear a high pitch whining sound for about 1 second. And after the truck has been shuddering, I notice a lower pitch whining sound when I accelerate now also. I don't know man, with the shuddering and the whining sounds, do you think it could be the torque converter?
    I really don't think it's the engine, there's no code, the plugs, wires, and fuel filter was replacing very recently. If it's the engine, I only other thing I could think of is a blocked cat.
  3. Oct 3, 2021 at 5:29 PM
    gearcruncher
    Canadain bumper technician
    In all honesty , I think you have 2 problems .
    If you rev up your engine when you are in park and hit 5000 rpm and do not see any shaking , all you are doing is spinning the engine with zero load .
    Then if you hold the brakes hard ,put the transmission into drive and bring the engine revs up to 1500 you feel shaking .
    If the engine is not under load , it will be incredibly difficult to feel the motor chug .
    The sounds you are hearing could be an issue with the transmission pump or the torque converter
    This being said , these things need to be diagnosed properly in order to save you some cash .
    What kind of scanner are you using to check for codes ?
  4. Oct 3, 2021 at 6:22 PM
    fixingseanpdx
    Portland, Or
    I used a harbor freight obdII scanner that I had used on other vehicle before.
    Would you recommend just changing the torque converter and do a trans fluid flush ,and maybe a new trans filter to see if that would fix the problem.
    I don't personally know any trusted shop in the Portland, Or area, so I'm very hesitant to take my truck to some shop. Chances are that they'll tell me that I need a new engine and transmission.
    I don't know gearcruncher, what would you do, if this was your truck?
  5. Oct 4, 2021 at 10:05 AM
    fixingseanpdx
    Portland, Or
    Hey Gearcruncher, how hard is it to replace the transmission oil pump. Since I'll be taking the transmission out to replace the torque converter anyway I figure I can just swap out the pump too if it's easy.
  6. Oct 4, 2021 at 4:46 PM
    gearcruncher
    You need special tools to replace the pump . Special tools to align the pump and special tools to re-ring the pump .
    At this point in time , I wouldnt hesitate to run your truck by a transmission shop in Portland and get their opinion of the problem .let a professional drivetrain specialist burn up a few gallons of your gas with you in the passenger seat explaining the problem as he drives your truck . Those guys diagnose problems such as yours every day . Explaining your problem to me over a long distance keyboard is no where near the opinion you can get if you let these guys drive your truck for free
    I have always offered free road tests to anyone that comes to the shop . A quality transmission shop will always offer free road tests .
    A free road test is a free road test . All you are looking for is an opinion on where the problem may be .
    You can leave the transmission shop with an opinion from a professional who fixes these transmissions on occasion .
    There are zero obligations for you to drop thousands of dollars . Road tests are free .
    Transmission shops in 2021 are both swamped and backlogged fixing GM , Ford and Dodge products . They are making big bucks on the domestic stuff at present . Domestic crap is designed to last until the warranty period is over . Toyotas transmissions are tough if treated properly can last 500,000 miles
    Get a senior technician in your drivers seat for a 5 minute test drive / road test and use that opinion to your advantage
    Did I mention road tests are free .
    Not everyone out there is in it to screw you over . Sometimes you have to let your guns down and get a professional in your drivers seat to help figure things out .
  7. Oct 11, 2021 at 4:43 PM
    Rebirtha
    Rebirtha Well-Known Member
    Lance
    PDX
    2015 TRD OR DCSB
    I'm getting the same kind of shudder but at 40mph on flat roads just cruising and just adding gas . It will cruise at about 1000 rpms at 40 and i give it a tad bit of gas it shudders then i give a bit more and it is gone . Never does this going uphill or downhill and only at 40
  8. Oct 11, 2021 at 5:45 PM
    gearcruncher
    Different year of truck , different transmission and different engine than the op . You may have a similar symptom but any diagnostics we try in this thread to help you fix your problem will only confuse the first generation owners .
    try here
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
