need AAL/suspension help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew-z, Sep 7, 2009.
  1. Sep 7, 2009 at 4:14 PM
    drew-z
    drew-z [OP] dude
    White 05 prerunner SR5 Double Cab
    AFE Brute Force CAI, pioneer touchscreen, pioneer flat series 12" sub/ custom box, window tint, HIDs, LEDs overhead, timbren suspension, BHLM, 2" leveling kit
    I have an 05 prerunner and I carry my 600lb 4wheeler in the back very often. I have the weak rear suspension problem and it sags and bottoms out easily, especially with the 4wheeler. I considered the supersprings but it sounds like they cause a rough ride when unloaded. So I am leaning toward the timbren rear suspension enhancement kit because it sounds like that would solve my problems. Will this lift my rear end? Would I also need to purchase something to level out the front end? Or is there something better that I should buy for less than $200?
    Any opinions and/or suggestions would be greatly appreciated.
  2. Sep 7, 2009 at 4:20 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    the timbren's do not lift the rear any. they just help when loaded
  3. Sep 7, 2009 at 4:27 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    timbrens will not lift the rear, they simply replace the bumpstops.
    have you thought about firestone airbags? they are only about $40 more than the timbrens and you can dial them in to exactly how you want them. you dont need any crazy compressor or anything, a simple bikepump will work for them.
  4. Sep 7, 2009 at 5:06 PM
    drew-z
    drew-z [OP] dude
    well i might buy the timbrens only to save $$. how bout any suggestions on an AAL and leveling kit?
