Need advice about lowering my 2nd gen sr5 tacoma
Discussion in 'X-Runners' started by beandowman, Nov 28, 2017.
  1. Nov 28, 2017 at 6:47 AM
    beandowman
    beandowman [OP] Member
    Dean
    2012 Tacoma SR5 5 lug
    I asked on the 2nd gen forum and they told me the best info would be here. I ordered the djm suspension kit with 4 inch blocks in the rear and the UCA and LCA. Im not very mechanically inclined and this is my first time modding/ lowering a vehicle and i want to make it right. Right now i have style 95 BMW wheels to put on it with one inch spacer/adapter. Specs of the wheels are 19x10 +22 offset in rear, 19x9 +22 offset in front. Im stuck on tire sizes. I dont want super low profile tires and i do not understand tire sizes at all. If anyone could help thatd be great. Thanks.
  2. Nov 28, 2017 at 6:50 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  3. Nov 28, 2017 at 7:27 AM
    beandowman
    Dean
    Thank you.
    inwood customs likes this.
  4. Nov 30, 2017 at 10:24 AM
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    Well first off those wheels with a 1" spacer will be quite prominent of the fenders. My 18x9 et20 stick out a little bit with their 255/45 tire, so adding 1-1.5" to that would likely require flares to adequately cover them (unless you like that look).
    For the tire size(s), are you planning on running the same tire on all four corners? or a staggered setup? Use this online calculator tool to figure out the best size(s): . Plug in your stock size (215/70/15) and find a tire that is as close to that diameter as possible. A decent starting place might be 255/40/19 and 285/35/19 front to rear. However I would suggest finding a wheel that is a bit more friendly as far as fitment goes.
  5. Dec 3, 2017 at 12:26 PM
    beandowman
    Dean
    Id be running a staggered setup and i like the more of a poke look. Thanks for the advice once i get everything on ill post a picture of it.
