Need advice after frame replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Sep 27, 2019.
  1. Sep 27, 2019 at 5:13 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    Got a call from dealer that truck is done , frame replaced. But they tell me the horn is not working and not sure why. They think it’s the clock spring. Horn worked when I dropped it off. And now they say it’s on me to replace the clock spring! What can I do here?
  2. Sep 27, 2019 at 5:14 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You should tell the dealer it worked before you dropped it off, so you need to fix it.
    Silentshredr likes this.
  3. Sep 27, 2019 at 5:16 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I did do this but they said Toyota doesn’t cover incidentals. Like wtf. I’m sure they arn’t cheap either
  4. Sep 27, 2019 at 5:17 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Clock spring was a recall on some years too. Go to Toyota.com and enter your Vin.
  5. Sep 27, 2019 at 5:21 PM
    spitdog
    You should have said, it’s not an incidental when it worked before I dropped it off, it must have been a blunder on the mechanics procedure.
  6. Sep 27, 2019 at 5:22 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    It's not a incidental if they broke it..... Sounds to me dealer needs to fix it. Not Toyota
  7. Sep 27, 2019 at 6:48 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I actually had this recall done in 2012
  8. Sep 27, 2019 at 7:07 PM
    81shark
    81shark Well-Known Member
    They broke it they bought it. They broke my uppper control arm bolts. They didn't ask me to pay for it
    gotoman1969 and tammikm[OP] like this.
  9. Sep 27, 2019 at 7:37 PM
    vastresources
    vastresources New Member
    2007 Tacoma, NEW FRAME, STRUT/SHOCKS, FRONT DRIVE AXLES, LOWER A ARMS, BALL JOINTS, TIE ROD ENDS, AIR COND COMP, ROTORS, DRUMS, PADS AND SHOES
    Wore a hole in the drivers seat.
    Seriously? I don't know who your service was done by but when they tear your truck apart, (Mine is 07, frame replacement last August) and it's ten years old, crap is gonna break, period. Toyota was more than fair to me I believe. They told me up front that they wouldn't charge me a dime in labor to put all new parts on instead of the current (old) ones back on the new frame, so I had everything replaced, purchased by myself, online and delivered to the dealership. Lower A arms, ball joints, tie rod ends, quickstruts, CV axles, calipers and rotors, etc. Maybe you need a new dealership.
  10. Sep 27, 2019 at 9:05 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    If it definitely worked when you dropped it off, then it sounds like someone forgot to tie down the steering wheel before they popped the shaft.
    Sucks for them as the clock springs are so unreliable they were covered by a recall (or TSB?) and it was bound to happen anyway, but if you're sure you had a horn before, that's their problem.
    If you're not that sure... well... it coulda just broke. I had my truck inspected in January, it was done by kinda-friends, but I'm sure if something failed they would have told me even if they let it slide, which I doubt. Went to hit the horn sometime this spring, and it has no horn. So it's not like it's a slam-dunk that they broke it unless you're sure...
  11. Sep 28, 2019 at 3:01 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Contact toyota and file a complaint. These damn dealerships need to be held accountable.
    There are probably other problems that you have not found yet, Take a good look at everything.
  12. Sep 28, 2019 at 3:02 AM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    would they have had the steering wheel off to do the frame replacement? I did have the replace the intermediate steering shaft, but not sure if they would need to take all this apart to fix that?? I am sure it worked when I dropped it off
  13. Sep 28, 2019 at 3:08 AM
    fixnfly
    S.W.PA
    Yes, the steering shaft is disconnected to remove the cab.
    Someone must have let the wheel turn while it was disconnected. Amatures
  14. Sep 28, 2019 at 5:39 AM
    fb40dash5
    11 V6 AC 4x4
    Yep, if you let it flop and it turns too far sometimes that's enough to break them, and if it's reinstalled a turn off, you'll snap it when you hit full lock.
    There's fancy tools to keep the wheel in place, I always just ran a cheapy tie down strap to something under the seat, takes all of 15 seconds.
    TRDSport10 likes this.
  15. Sep 28, 2019 at 6:32 AM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    After going back to dealership and discussing with them they are going to cover the clock spring on their dime as they should.
    Thanks Guys!
