NEED ADVICE AFTER HAVING MY FRAME REPLACED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Prim3sTacoma, Jul 5, 2022.
  1. Jul 5, 2022 at 8:27 AM
    Prim3sTacoma
    Prim3sTacoma [OP] Active Member
    Long Island
    11 4dr trd blue
    Blue balls, full stereo rewire and upgrade, Bullbar custom painted grill roof rails supercharger and trd intake and exhaust bronze rims new tires. Custom headlights with bi-xenon and projectors
    HELLO TACO FAM, SORRY IF THIS IS A DUPLICATE BUT I NEED SOME HELP. SO I HAVE A 2011 4X4 DC AND I JUST HAD MY FRAME REPLACED AND LOOKS LIKE THE DEALER ONLY DID THE BARE MINIMUM WHEN THE REPLACED MY FRAME. SO MY QUESTION IS THE "MONK" OCD IN ME IS LIKE OK A NEW FRAME BUT EVERYTHING ELSE NEEDS TO BE REPLACED BEING 1) OVER 10 YEARS OLD AND 2) LOOKS STUPID EVERYTHING OLD LOOKING AND WORN. SO MY OCD IS TELLING ME TO REPLACE THE LEAF SPRINGS, UPPER AND LOWER CONTROL ARMS, OUTTER TIE ROD ENDS AND THE SWAY BAR LINKS. LIVING WHERE THE ROADS CAN DEF RUIN EVERYTHING I FEEL LIKE ITS JUSTIFIABLE. I DID HAVE THE OEM BILSTEINS FRONT AND REAR REPLACED WITH NEW STRUT MOUNTS. AFTER LOOKING INTO THIS A BIT I HAVE NO IDEA WHAT BRAND TO GO WITH. OEM IS VERY PRICEY AND I FEEL LIKE AFTERMARKET DEPENDING ON THE BRAND MIGHT SAVE ME A FEW DOLLARS IN THE LONG RUN. I DONT NEED TO LIFT OR LEVEL IT SO I WANNA MAINTAINE ITS RIDE HEIGHT WITH THE BULLDOG STANCE. SO WHAT BRANDS CAN YOU RECOMMEND AND IF I MISSED ANYTHING PLEASE ADD TO MY LIST. OH AND THEY CUT MY AXLE BOOT SO THATS EITHER GONNA NEED A REBOOT OR A NEW AXLE. SUGGESTIONS? THANK YOU AND SORRY FOR THE LONG THREAD LOL.
  2. Jul 5, 2022 at 8:33 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    You're asking about replacing things that aren't broken, and using non-OEM parts to save a few bucks? :crazy:
    Evostaco and Prim3sTacoma[OP] like this.
  3. Jul 5, 2022 at 8:41 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    CAPSLOCK.
  4. Jul 5, 2022 at 8:42 AM
    Prim3sTacoma
    Long Island
    11 4dr trd blue
    LOL WELL YES, HEAR ME OUT. SO I KEEP MY TRUCK LOOKING PRETTY SHARP CONSIDERING THE AGE AND LIVING IN NY THE ROADS HERE SUCK. SO LIKE I SAID MY OCD WANTS ME TO REPLACE EVERYTHING THATS DEF WORN. NOT BROKEN BUT WORN. I STARTED ASKING MY LOCAL DEALER ON PRICES AND WOW THE PRICES ARE DEF MORE THAN AFTERMARKET SO I WANNA REPLACE THEM WITH BETTER AFTERMARKET PARTS SO YEAH I KNOW SOUNDS CRAZY BUT ITS LIKE GETTING DRESSED AND GOING OUT WITH NO PANTS ON LOL I WANNA DO IT RIGHT. SO BARE WITH ME NO PUN INTENDED LOL TY
  5. Jul 5, 2022 at 8:43 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Please stop with the Caps locks. Just go OEM
    Naveronski, SH10151 and Gen3TacomaOBX like this.
  6. Jul 5, 2022 at 8:47 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I'd recommend your perform a TW search for each of the items you are considering to replace.
    Also please be kind and remove your caps lock (so that all letters are not uppercase.)
    Congrats on your new frame.
  7. Jul 5, 2022 at 8:48 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    What sort of preventive maintenance did you do with the frame since you acknowledged living in a salt state?
  8. Jul 5, 2022 at 8:49 AM
    Prim3sTacoma
    Long Island
    11 4dr trd blue
    Sorry at work and we use caps all the time my apologies and thank you.
  9. Jul 5, 2022 at 8:50 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    you get what you pay for...if you "like" your truck the way it is..and want it the same but newer, spend the money and use OEM parts, cheaper parts are cheaper for a reason.
    Shellshock likes this.
  10. Jul 5, 2022 at 8:52 AM
    Prim3sTacoma
    Long Island
    11 4dr trd blue
    so far just the frame was replaced with brake lines and the hardware and lower steer shaft. So living in a salt state I wanna replace as much as possible.
  11. Jul 5, 2022 at 8:53 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  12. Jul 5, 2022 at 8:55 AM
    Prim3sTacoma
    Long Island
    11 4dr trd blue
    I get that but when it comes to my truck I almost try to say i spare no expense but for example oem leaf springs? or ironman or old man? I was hoping for better direction thats all
  13. Jul 5, 2022 at 9:36 AM
    spitdog
    Since you have a new frame there’s no need to randomly start replacing parts. I would save the money and only have the undercarriage sprayed with a corrosion protection like fluid film or thicker wool wax or something of your choice. Protect what is new and don’t go down the rabbit hole because you want new parts on your new frame.
  14. Jul 5, 2022 at 10:02 AM
    MSgt O
    2013 Tacoma
    Ok so front/rear springs...lets start there. Find a set of 3rd gen take offs on FB marketplace or on the for sale forum, most aftermarket springs are "lifted" and you dont want that. 3rd gen ones fit with no issue, you could also use the 3rd gen UCAs, but NOT the lowers, they are different. then look at LCAs, and use OEM for that...should save you a BUNCH of money doing it this way. If you DONT want the front lited stay away from 3rd gen TRD Off Road ones..
  15. Jul 5, 2022 at 10:04 AM
    MSgt O
    2013 Tacoma
    next step is to determine whats next...tie rods, ball joints, steering rack...theres a million parts you CAN change..but do you really NEED to...and only you can answer whats sagging, sloppy, loose...
