Need Advice: Bearing / Hub Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PNW08, Sep 11, 2022.
  1. Sep 11, 2022 at 2:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d scrub the rust off those splines. Then add a bit of grease to them.
    I used a “THIN” coated of Lucas Red n’ Tacky. Brand and type doesn’t really matter.
    That’s what I used because that’s what was handy.
    tacoman45 and PNW08[OP] like this.
  2. Sep 11, 2022 at 2:33 PM
    PNW08
    PNW08 [OP] Active Member
    Washington
    08 Tacoma 4.0l
    How easily did the cv seat after doing that? The rust color in the picture is actually anti seize. Regardless, I am going to scrub the splines until they're spotless and reapply a little lithium grease as you said.
  3. Sep 11, 2022 at 3:02 PM
    TnShooter
    Deogee
    STOCK
    Mine slide right on the with no issues.
    It only got a slight bit tight when it was almost all the way seated into the knuckle.
    And that was due to the knuckle and not the spline shaft.
    I’d be careful using the axle nut to press it on. I personally wouldn’t recommend it.
    If you ever have to remove the hub again, it’s not going to be fun.
  4. Sep 11, 2022 at 3:11 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    That's exactly what I'm worried about. If I ever have to change a cv or hub I'm going to have to beat the crap out of it
  5. Sep 11, 2022 at 3:13 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    The factory hub took very little effort to remove from the cv.
  6. Sep 11, 2022 at 3:13 PM
    TnShooter
    Deogee
    STOCK
    Or worse, take the knuckle off with the CV and THEN beat on it. Not good.
  7. Sep 11, 2022 at 3:14 PM
    TnShooter
    Deogee
    STOCK
    Mine practically fell out.
  8. Sep 11, 2022 at 3:20 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    Which leads me to believe something isn't right about the new hubs
  9. Sep 11, 2022 at 3:23 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    The factory hub is back on the truck and it went back on easily.
  10. Sep 11, 2022 at 3:31 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    When you get to the point of replacing the cap on a new hub, just use a pair of pliers or channel locks, go around the cap, slightly bending the lip in. This will take several tries but you'll eventually get that lip curled in enough to get it started. Then you can smack it in with a rubber mallet or dead blow hammer.
    Put grease all around that lip before you seat it and it will help keep water out.
    PNW08[OP] likes this.
  11. Sep 11, 2022 at 3:34 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    Thanks for the tip!
  12. Sep 11, 2022 at 3:55 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    I’m curious, try counting the splines on your CV versus the new hub.
  13. Sep 11, 2022 at 4:05 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    The truck is my daily so I had to put it back together with the factory hub. I counted the splines in the new hub and there's 30. I don't think it's a spline count as I can get the factory cv to pass through the new hubs just enough to get the axle nut threaded on but that's it. After that, the only way to get cv to pass through is crank down the axle nut and it gets stiff real quick
  14. Sep 11, 2022 at 4:06 PM
    PNW08
    Washington
    08 Tacoma 4.0l
    Tried both new hubs on the same axle, same result
  15. Sep 11, 2022 at 4:07 PM
    #35
    TnShooter
    Deogee
    STOCK
    I’m going to have to agree.
    I suppose it’s worth asking, but is the CV axle OE?
    If so, it’s a hub issue.
  16. Sep 11, 2022 at 4:07 PM
    #36
    PNW08
    Washington
    08 Tacoma 4.0l
    Yeah the cv is oem.
  17. Sep 11, 2022 at 4:09 PM
    #37
    PNW08
    Washington
    08 Tacoma 4.0l
    Not sure what brand the hubs are. Dorman or something
  18. Sep 11, 2022 at 4:09 PM
    #38
    TnShooter
    Deogee
    STOCK
    Then the splines or bore in the hub is under sized.
    I’d try new hubs.
    PNW08[QUOTED][OP] likes this.
  19. Sep 11, 2022 at 4:10 PM
    #39
    TnShooter
    Deogee
    STOCK
    That explains it. Doorman is certainly not high on the quality list in my opinion.
    steelcity2 and PNW08[QUOTED][OP] like this.
  20. Sep 11, 2022 at 4:20 PM
    #40
    TnShooter
    Deogee
    STOCK
    FWIW, I went with Beck/Arnley assemblies.
    If you want the best, buy from @05Taco4x4
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-6-lug-2wd.537080/
    If you want to know why I didn’t buy from him. (Because I get asked this a lot)
    It’s because I bought “expensive” hubs from a former member here. Who’s since been banned.
    Those hubs didn’t last 30k. And I’m stubborn. So I said Fùćk it, and bought “middle of the road” assemblies this time. Because I was still crying over the price of the first ones I bought. I can’t give you good opinion on the B/A assemblies. I’ve only had them on for about 15k. I will say that the dust seal they send were loose in the back of the knuckle. I had to modify mine with a hammer to make them fit tight.:D
    Again, I HIGHLY recommend @05Taco4x4 assemblies.
