Need Advice: Bearing / Hub Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PNW08, Sep 11, 2022.
  1. Sep 11, 2022 at 4:24 PM
    #41
    PNW08
    PNW08 [OP] Active Member
    Washington
    08 Tacoma 4.0l
    Thanks man, very much appreciated
    TnShooter likes this.
  2. Sep 11, 2022 at 4:27 PM
    #42
    PNW08
    Washington
    08 Tacoma 4.0l
    Really appreciate everyone's help
  3. Sep 29, 2022 at 9:20 PM
    #43
    PNW08
    Washington
    08 Tacoma 4.0l
    I wanted to update you guys that I did actually get the bearings to seat on the cv shafts. I cleaned and basically polished the cv splines. This really didn't make much difference and the fitment was still very tight but I drew them in by tightening the axle nut. I really didn't like doing this but I wasn't going to give up. I hope I don't have to replace a cv anytime soon. I would probably need a press of some sort lol.
  4. Sep 29, 2022 at 10:01 PM
    #44
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Worst case, you sacrifice an axle nut.
    Basically you back the axle nut off until it just over hangs the end of the cv shaft threads.
    Them Tappy, Tap, Tap, and a Shmaaack. And drive it out the with a hammer.
    What you don’t want to do is damage the cv thread. So definitely don’t beat on the cv shaft.
    That’s why you use the nut :thumbsup:
    PNW08[QUOTED][OP] likes this.
  5. Sep 30, 2022 at 5:43 AM
    #45
    PNW08
    Washington
    08 Tacoma 4.0l
    I actually found out just how delicate those cv threads are while doing this job... I was removing the axle nuts with an impact gun and the socket slipped of the nut on one side. It ended up chewing up a couple threads near the end of the axle. Luckily, I had anticipated the possibility of this (read a couple horror stories here on tw) and had already purchased a set of thread chasing files. They worked suprisingly well and I was able to fully restore the threads.
  6. Sep 30, 2022 at 3:34 PM
    #46
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, they are easy to booger up. I have a nice piece of 1" brass rod that's about a foot long. I can hold it with a pair of channel locks and wail the crap out of it with a BFH, and not damage stuff too much.
    The only bad thing about that is, sometimes I get impatient and start wailing with the hammer and then get irritated with myself for having to fix one more thing I could have avoided.
  7. Sep 30, 2022 at 3:51 PM
    #47
    PNW08
    Washington
    08 Tacoma 4.0l
    Yeah I pretty much would have been screwed if I didn't have those files.
  8. Sep 30, 2022 at 4:04 PM
    #48
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    What he said. Changed a seal on the front diff a few months ago and the factory CV did not want to gracefully exit from the factory hub. Threaded the nut on and went to town with the BFH, thinking I could save the threads on both. I ended up sacrificing (unintentionally) the nut and a local TW member hooked me up with a spare! $5 nut vs a few hundred $$ for a CV axle is an easy choice!
    TnShooter[QUOTED] and PNW08[OP] like this.
  9. Sep 30, 2022 at 4:06 PM
    #49
    PNW08
    Washington
    08 Tacoma 4.0l
    My cv axles required little effort to get them out of the factory hubs. My problem was getting the factory axles to seat in the aftermarket hubs. The fitment seemed way too tight.
  10. Sep 30, 2022 at 4:07 PM
    #50
    Bishop84
    Bishop84 Well-Known Member
    I've buggered many cv axle threads lol..
    Thread files are amazing things to own.
  11. Sep 30, 2022 at 5:13 PM
    #51
    winkel
    Corydon, IN
    Everyone should own a thread file. I have one I got from my dad about 40 years ago. I've only used it a couple of times but it's been a life saver when needed.
    PNW08[OP] likes this.
  12. Sep 30, 2022 at 8:29 PM
    #52
    PNW08
    Washington
    08 Tacoma 4.0l
    I hadn't actually used one before this but now I agree, very valuable tool indeed. I got a set off Amazon that covers a big majority of standard and metric thread pitches.
