Need advice/help with choosing new clutch & flywheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomakid89, Mar 19, 2023.
  1. Mar 19, 2023 at 5:24 PM
    tacomakid89
    tacomakid89 [OP] Awesome Member
    William
    Austin, Texas
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime, King coilovers with remote resi in front, Kings with remote resi in rear, Deaver J66 leaf packs, TC UCAs up front.
    I've been doing quite a bit of reading about what type of clutch to run on my 2010 Tacoma 4.0 w/ a 6-speed. I off-road maybe 1-2 times a month and other than that it's just commuting with little traffic. For upgrades that have to do with the clutch, I have a short throw shifter, 33s, and DTLT headers on it. I was thinking of going with a stage II clutch and lightweight flywheel off of URDUSA.com but now I'm thinking that the Aisin stage I clutch kit and Luk flywheel off of Amazon or local auto parts store is the way to go. I will also get the throwout bearing upgrade/repair kit and a rear main seal from URDUSA. My 2 questions are; Does that setup sound about right for what I do? And are there any recommendations for which Aisin clutch kit to get? Thanks a lot for any help, I'm open to all opinions/recommendations. Update. The stock clutch has close to 170K miles on it and has started to slip which is why I will be replacing it and the T/O bearing has been squeaking for the last month or so.
  2. Mar 19, 2023 at 6:22 PM
    tacomakid89
    William
    Austin, Texas
  3. Mar 19, 2023 at 6:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Seems like a lot of off-road guys go with a heavier flywheel.
    The momentum of the heavier flywheel helps low rpm torque.
    @6 gearT444E might be able to better advise you on what might fit your needs.
  4. Mar 20, 2023 at 3:02 AM
    tacomakid89
    William
    Austin, Texas
    That's what I've heard as well. Any recommendations as far as brand goes? Thanks.
  5. Mar 20, 2023 at 4:06 PM
    tacomakid89
    William
    Austin, Texas
  6. May 2, 2023 at 7:34 AM
    tacomakid89
    William
    Austin, Texas
    Any suggestions? Thanks
  7. May 2, 2023 at 8:21 AM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    6 gearT444E and GilbertOz like this.
  8. May 4, 2023 at 3:24 PM
    tacomakid89
    William
    Austin, Texas
  9. May 4, 2023 at 6:57 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Stock is good but for heavy wheeling the heavier flywheel and URD stage 2 clutch is a nice upgrade. Tilton TOB is good to slap in there. I did a clutch masters and mines still going but alot of people have had issues with that bearing.
    bhigbee likes this.
  10. May 4, 2023 at 8:05 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Stock aisin
  11. May 5, 2023 at 6:17 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    I hope you're right, I'm going to get mine installed in the next couple of weekends.
    6 gearT444E[QUOTED] likes this.
  12. May 5, 2023 at 6:39 PM
    TacoTuesday1
    SD CA
    Heavy flywheel (I have)
    Stage 2 clutch (also have)
    Tilton TOB (want in the future, to replace my CM HydroTOB)
    On an off road 4x4, at least if N/A
    You’d generally want an FW same weight as stock or heavier
    because the crap 2.57:1 or whatever Tcase ratio doesn’t help
    a Fluidampr can also improve low RPM drive ability noticeably
    but nobody wants to be part of the 100 buyers necessary for FluidAmpr to develop one for the Tacoma, a $350 part that would greatly improve both performance and reliability
  13. May 7, 2023 at 11:37 AM
    tacomakid89
    William
    Austin, Texas
    Thanks for the advice. What brand clutch do you have?
  14. May 7, 2023 at 11:38 AM
    tacomakid89
    William
    Austin, Texas
    What brand clutch and flywheel do you have?
  15. May 7, 2023 at 12:15 PM
    TacoTuesday1
    SD CA
    last time I replaced with stock equivalent Exedy TYK1515. Eventually upgraded to URD Stage 2. I believe it has a stronger pressure plate with more clamping force that I imagine is better off road, stiffer feel to compensate for the ease added by HydroTOB, etc
  16. May 13, 2023 at 10:18 AM
    tacomakid89
    William
    Austin, Texas
    Ya I was hoping to go a URD Stage II clutch but they've been out of stock for quite some time now. I'm not sure what other brands make a good stage II clutch which is why I'm considering keeping it OEM.
  17. May 13, 2023 at 10:24 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    URD
  18. May 13, 2023 at 12:50 PM
    TacoTuesday1
    SD CA
    or if you want to go cheap and have time for the truck on jack stands you can have the stock flywheel resurfaced at a machine shop for $50
  19. May 16, 2023 at 7:33 AM
    tacomakid89
    William
    Austin, Texas
    thanks. I just realized you said that in your post.
  20. May 16, 2023 at 7:34 AM
    tacomakid89
    William
    Austin, Texas
    I figured as long as it’s getting replaced then I might as well get it all replaced.
