Need advice on a 3" Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dobro821, Jul 24, 2016.
  1. Jul 24, 2016 at 10:12 AM
    dobro821
    dobro821 [OP] Member
    2015 Tacoma DCSB TRD Off-Road 4x4
    Hello all Taco Drivers!!
    I need help with a 3" lift.
    I have a 2015 Tacoma DCSB TRD Off-Road 4x4 and want to lift it
    so I can fit 285/75/R16 under there.
    I'd like to do a 3" lift. What kind should I buy?
  2. Jul 24, 2016 at 10:19 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    First time THIS question has ever been asked.....;)
    First off, WELCOME! Most here are friendly and won't bite. Some will. And ChasPride will be here soon to like your post. A given.....
    Will 285/75/16's fit (without cutting) NO.
    Can they be made to fit. Yes:sawzall:
    What kind of kit? Answers range from sublime to the ridiculous. Give us a budget. Do you plan on off roading? How much off road?
    Get ready to have your world rocked.....You're about to hear every conceivable opinion known to man.
    vrod671, DustStorm4x4, Pigpen and 2 others like this.
  3. Jul 24, 2016 at 10:40 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Are you mechanically inclined? Are you dead set on 3"s of lift and 285's? Again, budget will determine what people will provide for advice. First off 285's are probably too wide for your stock wheels depending on the tire manufacturer. Ballpark you're looking anywhere from $2k with cheaper options like spacers and blocks. Nobody wants to see that. A decent coil/strut lift, leaf springs uca's, wheels, tires and you're headed towards $3k and up. Sky is the limit from there. Still interested?
  4. Jul 24, 2016 at 11:05 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    285's are recommended to be on 7.5" to 9" wheels.....Stock are 8". Perfectly fine. They MIGHT rub the UCA's but that can easily be remedied with wheel spacers. (ie, 3/4" Bora spacers best IMHO)
    Tires, $800 to $1000 on average.
    Good lift kit (5100's, OME coils, AAL) $733 (from Headstrong Offroad)
    Stay with 2-1/2" lift and avoid new UCA's/3", figure $400 to $1000 for UCA's
    I did 5100's, OME 885X's (w/1/2" top plate spacer), Deavers 2" AAL. @ $733. (2-5/8" of front lift) Did install myself. Goodyear Duratrac 265/75/16's @ $810, stock wheels, Bora spacers $205, and a Headstrong U-bolt flip kit for $80. (Approx $1850) Alignment numbers perfect.....Truck rides great,, looks great, performs (off road) great, and handles (on road) great. Will be putting 285's on soon. I've ran a set (belonging to someone else) for about 100 miles and was very happy with that experiment. Deciding on which brand of tire at the moment. Also considering 255/85/16's as an option.
  5. Jul 24, 2016 at 11:08 AM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
  6. Jul 24, 2016 at 11:16 AM
    dobro821
    Thanks for the welcome.
    My goal is this....I want more aggressive-looking tires and rims.
    I want to lift the truck just a bit solely to put something like 33" tires under.
    I'm not dead set on 285/75/16's, but I mean if I'm going to do a lift I want something in the tire size range.
    If I can't do a QUALITY lift for under $1000, I'm not doing it.
    I was liking the strut spacer for front/AAL or block in the rear but a lot of folks say that this is not a quality lift due to pretensioning and limited travel for UCA. Is this true?
    I don't want anything half-ass on my vehicle, but I'm not prepared to spend over $1000 merely to install more aggressive rims/tires. What is the most economical option for my goal?
  7. Jul 24, 2016 at 11:19 AM
    3coma
    rob
    This thread would be useless without mentioning the possibility of having to trim, cab mount chop, remove mud flaps.
  8. Jul 24, 2016 at 11:24 AM
    dobro821
    Thanks Bluegrass Taco.
    You are happy with your Headstrong Offroad setup? It ran the 285's fine and no problems with the UCA's?
  9. Jul 24, 2016 at 11:26 AM
    dobro821
    Oh, did you have to trim anything?
  10. Jul 24, 2016 at 12:24 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    You can drive around on flat ground with 285's and no cutting on a 3" lift. Just don't do much sharp turning or any flexing suspension....285's WILL rub HARD.
    I'm VERY pleased with the set up I went with. Affordable and still has great performance. Point is NO 3" lift will give you "no trimming" tire clearance for 285's.....
    Pigpen likes this.
  11. Jul 24, 2016 at 2:48 PM
    Pigpen
    Dan
    Northwest Montana
    I have a similar lift to Bluegrass Taco and run 255/85/16 tires on stock wheels - No trimming and no (significant) rubbing with stock components. I recently changed a few things (spent more money) now no rubbing at all.
    Check the tire size calculator to see the difference in those tire sizes. Welcome to the rabbit hole, Alice!
  12. Jul 24, 2016 at 3:29 PM
    hollandhunter
    hollandhunter Well-Known Member
    2015 Tacoma DCSB sr5 4x4
    Im running 3inches with 285 70 17s right now on my 2015. They will rub. Nothing a lil trimming wont fix. Dont be scared.
    An this time around i choose to install a ome kit in the front. 885s with nitroshocks and top plate spacer. Its stiff as hell on and offroad. Or to me it is. Im in the process of deciding weather i wanna go back to icon or venture onto unknown territory and install my first 6inch db lift. My opionon is if u want a 3inch lift save as much as you can and by the best you can. You get what you pay for in lift kits. JMO. Good luck.
  13. Jul 24, 2016 at 3:32 PM
    hollandhunter
    Oh and dont forget if you do come up with the $ to buy a good coilover lift like icon,fox,or king. Keep in mind you have to have the coilovers rebuilt from time to time. An that means taking them off and sending them into be rebuilt. Tons of research here. Searching long and hard will serve you best in tbe long run.
  14. Jul 24, 2016 at 3:35 PM
    Pigpen
    Dan
    Northwest Montana
    I love the ride of my 5100s with 885 coils and top plate spacers - Dakars on rear. My tires firm up the ride a little - load E Toyo M55 but the diameter smooths things out (33.4") 255/85/16
    hollandhunter likes this.
  15. Jul 24, 2016 at 3:43 PM
    hollandhunter
    For the money 5100s are the best hands down. Rather u wanna run ome springs or stock springs. For a couple hundred bucks there freakin great shocks. Cant say that about the ome shocks.
  16. Jul 24, 2016 at 3:48 PM
    Pigpen
    Dan
    Northwest Montana
    I had that debate internally. I had 5100s with stock coils set at 1.75" (2.5" actual lift) and really liked them, but wanted an upgrade. Instead of just switching coils, I put in whole new assemblies, but went with 5100s again.
    hollandhunter[QUOTED] likes this.
  17. Jul 24, 2016 at 4:18 PM
    TREED
    TREED Well-Known Member
    JT
    Spring Creek NV
    15 trd taco dc
    885x coils on 5100s. SPC upper a-arms 255/85/16 bighorns, 12k lb reciever mount rear winch,CBI offroad moab bumper,8k lb warn front winch, swaybar delete, spidertrax,icon minipacks, custom dog box, husky liners
    5100s with ome springs is a million times better than ome nitrochargers. 5100s at zero with 885x coils will clear bighorn 255/85/16 tires on stock wheels with the front mud flaps in place.
    Pigpen likes this.
  18. Jul 24, 2016 at 5:07 PM
    3coma
    rob
    And you might get away without needing uca's. It will only give you 2-1/2"s max though without spacers.
  19. Jul 24, 2016 at 5:08 PM
    Pigpen
    Dan
    Northwest Montana
    That's why I put in spacers
    Edit: I also put in spacers to take advantage of the available travel in the strut that we don't get to use without the spacer.
    TREED likes this.
  20. Jul 24, 2016 at 5:16 PM
    3coma
    rob
    So you're also running aftermarket UCA's which will blow his $1,000 budget?
