Need advice on Engine Vibration
Discussion in '4 Cylinder' started by vikx, Dec 20, 2011.
  1. Dec 20, 2011 at 10:56 AM
    vikx
    vikx [OP] Member
    Washington State
    Tacoma
    Hello all,
    I'm a newbie to Toyotas. My truck has a 2.4 L with automatic. 54K miles. 2WD. The motor seems to vibrate at idle, shakes the steering wheel slightly, also seems to idle too fast. Accelerates OK from a stop. It actually seems to run pretty smooth; the idle vibration is driving me NUTS. Any thoughts?
    Thanks in advance.
  2. Mar 31, 2012 at 4:52 AM
    gcoates
    gcoates Member
    When sitting at a light, if you take it out of gear does the vibration stop ?
  3. Apr 1, 2012 at 10:12 AM
    vikx
    vikx [OP] Member
    Washington State
    Tacoma
    The vibration happens in drive or neutral. It's like the engine is idling a little fast. Nothing I can put my finger on, just not a "smooth" running motor. The truck seems to run fine, starts every time, no other issues. I've never had a Tacoma before, but don't think this is normal? Thanks for the help.
  4. Apr 3, 2012 at 8:15 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
  5. Apr 4, 2012 at 9:04 AM
    vikx
    vikx [OP] Member
    Washington State
    Tacoma
    Thank you for the link! This one has certainly never "purred like a kitten".... LOL.
