Need advice on front axles and drivetrain
Discussion in '1st Gen. Tacomas (1995-2004)' started by 7c0m9, Jun 14, 2013.
  1. Jun 14, 2013 at 3:55 PM
    7c0m9
    7c0m9 [OP] New Member
    Loose steering on interstste and drivetrain movement starting and stopping. This is a video of the front inner axles slop.
    http://www.youtube.com/watch?v=oDyYjxYVXn4
    Both sides are equally loose and sloppy. Not sure what parts need to be replaced. Please advise thanks.
  2. Jun 14, 2013 at 10:12 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Pretty sure thats within normal range.. As long as the seal isn't leaking you should be fine. Mine have play like that and i replaced the front diff last year. How many miles? lots of things can contribute to wandering on the highway, loose ball joints, rack and pinion wear, steering shaft slip joint, tie rod ends, control arm bushings, alignment. List some specific things your truck is doing
    Welcome to TW
