Need advice on how to deal with this
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beechlover, May 30, 2023.
  1. May 30, 2023 at 5:12 AM
    Beechlover
    Beechlover [OP] Member
    2007 Silver Tacoma TRD
    No mods
    Hey guys/gals,I was just made aware of two trouble spots on my frame (corrosion). See pics.
    I live in the DFW area and have tried calling at least 6 to 8 shops and they do not/will not do any work on frame corrosion. I’m currently at a loss as to how to get this fixed except to drive it out of state to where this is more common and find a shop up north. Any advice would be appreciated.23A491D4-E6C9-4A35-B9F7-D0738D55E54E.jpgA68F8B12-19A4-4740-9A9E-F4BA122942BB.jpg
  2. May 30, 2023 at 5:13 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Toyota had a recall for frame rust. Have you tried Toyota?
  3. May 30, 2023 at 5:15 AM
    Beechlover
    No mods
    The recall has already expired. Funny thing is that I’ve had my truck in their shop for oil changes and such, and they’ve never said a word about this. I got these pics from another shop. (Not Toyota)
  4. May 30, 2023 at 5:26 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yea sorry man this sucks!
    Dealer maintained you would think you’re good to go!
    Maybe look for a welder not sure about inspection laws where you are.
    Here in Vt welds are a fail unless done by a certified welder.
    Good luck man!
  5. May 30, 2023 at 5:50 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Trade it in at a toyota dealership. Let it be their problem.
    SWPA Tacoma likes this.
  6. May 30, 2023 at 5:55 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Do you happen to know what code the welder needs to be certified under to repair frames?
    Then maybe it is just another state revenue generating gambit.
  7. May 30, 2023 at 6:06 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Do you have actual holes there or just the paint flaking up? Usually the rest of the frame is more rusted when holes develop there. Scrape away the loose paint with a screwdriver or scraper and post back.
  8. May 30, 2023 at 7:15 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Hold your dealer accountable for it..
    jackn7 likes this.
  9. May 30, 2023 at 7:18 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    He's 4-5 years past the frame warranty.
  10. May 30, 2023 at 7:21 AM
    Bivouac
    The Toyota dealers in Texas seldom see frame rust problems I could see how the tech doing service might never even noticed.
    I have no idea how the Texas Motor vehicle code is gotta be some Texas welders that can fix this.
    Shops are scared of liability and might not have the insurance to cover working on vehicles. because of the catching on fire,
  11. May 30, 2023 at 8:43 AM
    Beechlover
    No mods
    No holes were found, it’s just rust scaling. There is solid metal underneath those spots. My thinking is it just needs to be cleaned up and some spray on rust preventative applied. I’ve got a few spots like that but not bad at all.
    gkomo and Bivouac like this.
  12. May 30, 2023 at 9:10 AM
    Bivouac
    I was wondering how a Truck in the DFW area was exposed to enough winter to be a concern.
    Lots of Surf fishing as the tide rolled in?
  13. May 30, 2023 at 9:17 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I know nothing about truck construction, but in building construction, you hit surface rust with a special wire brush to work out and remove the softened steel and active rust and then use a rust inhibitor coating. If it comes in a spray can, it's not likely to be a very effective rust inhibitor, but Sherwin Williams, PPG and others have good brush applied products that do the trick.
  14. May 30, 2023 at 9:19 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Wire wheel then a give it a coat of your favorite undercoating. Should be good to go. Really glad no holes were found!!!!
    dangeroso likes this.
  15. May 30, 2023 at 9:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Ha! Why do you get a shop involved then?
    1. Scrap off all the loose paint and rust.
    2. Sand/wirewheel if you want, then degrease.
    3. One coat of Rustoleum primer
    4. Four coats of Rustoleum semigloss paint. Wait 15 minutes or so between coats.
    5. Let dry for 24 hrs.
    6. Spray a corrosion protectant like CRC Marine or Cosmoline RP-342.
    I do the above to all the rock scars on my frame and axle before each winter.
  16. May 31, 2023 at 7:02 AM
    Beechlover
    No mods
    I’ve had the truck since ‘09. I’ve lived all over the country Wisconsin, Colorado, Massachusetts, and now Texas. My guess would be my time in Wisconsin.
  17. May 31, 2023 at 7:03 AM
    Beechlover
    No mods
    Will do, thanks!
    jackn7[QUOTED] likes this.
  18. May 31, 2023 at 7:35 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    The second picture definitely looks like a hole. I'd be looking into trading it in before it gets worse.
  19. May 31, 2023 at 7:45 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    How is this "not a hole"? and yeah, clean it all up, fluid film or woolwax ASAP!!
  20. May 31, 2023 at 7:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sorry for you to say that if you whack that with a ball peen, probe with a screwdriver and look inside with a borescope you're going to find a mess that a wire wheel and spray paint won't fix.
    Way too late for that
    Please tell us how that would work. Oh yea, it won't.
    Jimmyh and MSgt O like this.
