Need advice on intake
Discussion in '4 Cylinder' started by Ilovetacos1, Mar 2, 2012.
  1. Mar 2, 2012 at 1:00 PM
    Ilovetacos1
    Ilovetacos1 [OP] Member
    Kyle S.
    Albuquerque
    00 Tacoma I4
    2in lift, front bumper,fog lights, tool box, exhaust, k&n filters, mud tires, nerf bars,
    I have a 00' taco with the 2.7 inline 4. I was curious if anybody has put a cold air intake on trucks similiar to this. if so, was the cost worth the gains? opinions on which brand to use and if I should go thru with it...thanks guys
  2. Mar 2, 2012 at 5:10 PM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Save your money and do the deck plate mod instead
  3. Mar 3, 2012 at 4:38 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    most cold air intakes are really hot air intakes due to the positioning of the air filter in the engine bay. They look good although your will get no power gains from them.
  4. Mar 3, 2012 at 7:18 AM
    armyman89
    armyman89 Member
    mikkel
    new market alabama
    2004 taco prerunner
    just get a AFE filter and call it a day CAI are worthless unless you have some sort of air dam under or bhiend your front bumper to pull cold fresh air in but all that is a waste of money if you go wheelin
  5. Mar 3, 2012 at 7:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^
  6. Mar 4, 2012 at 5:24 PM
    Ilovetacos1
    Kyle S.
    Albuquerque
    00 Tacoma I4
    sounds like i should scrap the idea than.
  7. Mar 4, 2012 at 5:37 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This.
    You already have a CAI. Like most modern vehicles (1990 and later?) it already draws cold air from the fender, or from a pickup in the radiator support.
    There are things you can do to reduce restriction, but honestly, your 2.7 is not going to demand more air than the 4.0, and the 4.0 does just fine towing 5000lbs on the stock intake.
  8. Mar 4, 2012 at 6:25 PM
    chriss
    chriss Well-Known Member
    chris
    There is test data around that shows this helps performance.
    Others should ask themselves how this mod would help. When it allows in "hot" air. The "cold air" mantra says it shouldn't.
    Improving flow is the key. Relieving flow restrictions and pressure loss is more important that a few degrees of temperature.
  9. Mar 4, 2012 at 9:31 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    i vote deck plate mod
    i've heard for the 4 cyl you can only use 3" but i fit a 4" on mine. just have to orient the screw holes correctly
  10. Mar 5, 2012 at 8:27 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Sorry to thread jack but Whipper you think that is your best comment ever?
  11. Mar 5, 2012 at 8:56 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    No I mean you think that is the best comment YOU have ever written on TW?
  12. Mar 5, 2012 at 8:57 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Well played.
  13. Mar 5, 2012 at 10:37 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Again, well played.
  14. Mar 7, 2012 at 1:57 PM
    Ilovetacos1
    Kyle S.
    Albuquerque
    00 Tacoma I4
    thanks for all the input...sounds like i might try the elbow mod, lessen the restriction..now change of subject...has anybody replaced the front struts on these trucks and are they easy to do...the shop wants to charge me 300!!
