Need advice on leveling kit
Discussion in 'Suspension' started by trd sport, Jun 30, 2014.
  1. Jun 30, 2014 at 10:13 AM
    trd sport
    trd sport [OP] Well-Known Member
    queens,ny
    07 double cab trd sport
    I own a 07 double cab long bed TRD Sport. It has been a great truck and after 88000 miles it is now due for a suspension change. I would like to basically level out the truck without getting into swapping out UCA's and maybe get a 1.5-2" lift in the process. My rear suspension has the upgraded 4 leaf from the dealer and I installed Firestone air bags with compressor and controller. The main question is which lift to go with without sacrificing ride quality as I do not go offroad very often, mostly highway driven and local NYC streets. Any advice will be much appreciated..
  2. Jun 30, 2014 at 10:18 AM
    field76
    field76 Well-Known Member
    Bozeman
    2012 PM TRD OR DCAB
    Debadged, audio upgrade, silex organizers, AVS in channel window vents, 5100s on all corners with Wheelers 3 leaf HD AAL
    You could use 5100's and your stock coils. I have mine set to the 1.85" setting and I do not notice a difference in ride.
