Need advice on Lifting truck with new wheels and tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Aug 18, 2022.
  1. Aug 18, 2022 at 9:55 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    I have a stock 21 DCSB planning my first big upgrade. Wondered if anyone has thoughts on the configuration below:
    1. Blistein 5100
    2. JD Fabrication Upper Control Arm
    3. Black Rhino guides with -10 offset
    4. ECGS bushing Install (don’t know what this is but was recommended by the shop)
    5. Weld cam tabs (don’t know what this is but was recommended by the shop)
    6. Wild peak at3 285/75r16
    7. Icon add a leaf
    is there anything I’m missing? I’m thinking a 2.5” lift with levelling.
  2. Aug 19, 2022 at 1:45 AM
    Yotasama
    Yotasama Member
    Jesse
    2022 dcsb
    Well ecgs bushing is not for everyone. Why change if ur bushing is fine. And that tire size shouldn't be rubbing if your alignment is properly adjusted. My buddy has 285/70/17 without cab mount chop and doesn't rub at all.
    Trucks2019[OP] likes this.
  3. Aug 19, 2022 at 7:30 AM
    Trucks2019
    It’s apparently due to some trucks sometimes getting vibrations when they are lifted and an install would be easier and cheaper if it was done at the same time as the lift. It’s $400 CAD extra for the parts and labour.
  4. Aug 19, 2022 at 7:33 AM
    SpeySquatch
    2016 TRD OR DCSB
    If you lift the truck it is very likely it will happen. I went through two needle bearings before finally switching out the bearing for the ECGS clamshell bushing. Save yourself the headache and do it now
    also, you will likely need a cab mount chop if you are going with 285’s
    the welded cam tabs isn’t exactly necessary, but will help keep alignment if you offroad rock crawl and the like
    Aqualoon likes this.
  5. Aug 19, 2022 at 7:35 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    You wont know its fine until after you lift the truck. Its a no brainer to do it will you have the front end apart to do the suspension. Its only $60
    Aqualoon and SpeySquatch like this.
  6. Aug 19, 2022 at 7:53 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    I have 285/70/17 with CMC and I still rub.
    ECGS is good to replace while you're doing a lift if you can.
  7. Aug 19, 2022 at 7:55 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Harsh beach driving flattened my alignment tabs. Def worth it if it ever leaves the pavement.
  8. Aug 19, 2022 at 7:58 AM
    Trucks2019
    Great, thanks. Super useful advice. Any thoughts on the wheels/tire set up. Will -10 offset with 285s cause rubbing without any chopping?
  9. Aug 19, 2022 at 8:05 AM
    Aqualoon
    Minnesota
    My -10 rubbed before trimming and CMC and rubs still. Others didn't have this issue, some only had to do some trimming and there were some like me, who still rub.. As odd as it sounds, it really is a truck by truck case.
  10. Aug 19, 2022 at 10:12 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    265 and no rubbing, nor a need for UCA's.
  11. Aug 19, 2022 at 4:53 PM
    dcarcagno
    dcarcagno Well-Known Member
    Seattle, WA
    2021 TRD Sport MGM
    How’s this look for an alignment? I’m getting a vibration at around 65. 2 inch lift. Ome control arms. 285 ko2s. 11F246DE-DF24-4756-AF96-13F1FB5B1710.jpg
  12. Aug 21, 2022 at 8:33 PM
    Trucks2019
    Thanks, did you just upgrade the shocks. Is anything required for bushings and what did you go with for wheel offsets. I think 32s might be more realistic to avoid rubbing.
  13. Aug 22, 2022 at 8:17 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Correct. Bilstein 5100s recommends you keep the OEM coils, so I did'nt bother with those, nor didnt do the bushings and still have the OEM OR wheels.
