NEED ADVICE ON NOSIE IN FRONT END AFTER 3" LIFT
Discussion in 'Suspension' started by jigger1976, Jan 13, 2011.
  1. Jan 13, 2011 at 4:39 PM
    jigger1976
    jigger1976 [OP] Well-Known Member
    ontairo
    06 tacoma 4x4 ddbl cab
    3" lift, GRILL VENT VISIORS,CAP WEATHERTECH MATS
    HELLO EVERYONE NEW HERE!!! I NEED ADVISE?? I JUST INSTALLED A 3" LIFT IN MY 06 TACOMA AND RIGHT AWAY NOTICED NOSIE IN THE FRONT END. I HAVE READ SOME OF THE THREADS AND NOW ARE CONFUESSED BADLY. SOME SAY FRONT DIFF. DRIVE SHALFT. HAS ANYONE GOT A SOLUTION FOR THIS AS I READ THAT EVERYONE PRETTY MUCH HAS HAD THE SAME PROBLEM AFTER LIFTING THE TRUCK...AND YES THE KIT WAS CHECKED ALL BOLT AND ALINGMENT WAS DONE. OH YA ADDED THE DIFF DROP SPACER TOO.:mad: RIGHT NOW I'M AT THE POINT OF TAKING IT OUT PLS HELP
  2. Jan 15, 2011 at 7:00 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    1. Please stop yelling
    2. The diff drop is probably the cause of the vibes. Remove it and see if they go away.
  3. Jan 16, 2011 at 12:52 PM
    jigger1976
    ontairo
    Thanks will try that.:) also ordered a set of shims from toytec for the rear just to try that.Thats a cheap fix to try. Has anybody narrowed it down to specific model of truck. Because not all people are haveing the same problem. ???
  4. Jan 18, 2011 at 8:01 AM
    jigger1976
    ontairo
    took the diff drop out today, didn't make a difference still nosie and vibra in the foot area. hopefully its the drive shaft just waiting on shims now.
  5. Jan 18, 2011 at 8:14 AM
    moulin6801
    moulin6801 Well-Known Member
    Please keep us posted! I want to lift my truck, but things like that is what is keeping me...
    Did you notice changes in MPG??
    thanks
  6. Jan 18, 2011 at 8:16 AM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
  7. Jan 18, 2011 at 11:34 AM
    jigger1976
    ontairo
    i dont think it the bearing? why because it happen right after the lift.. i noticed it with in the first mile . took the diff drop out but still nosie maybe a little less but still there. i read in another thread someone said it the drive shaft angle. i'm kinda think that it is. does anyone know the angles or what the angle tolerance are. I hope this is it and the shims will fix it.
  8. Jan 18, 2011 at 11:49 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Check to see if the vib goes away if you switch to 4x4 while driving... it could be the bearing because after the lift there is more pressure against the bearing due to the new angle of the cv's
  9. Jan 18, 2011 at 2:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Its def. the bearing man! My Truck is at the dealer (has been for 2 weeks) right now getting fixed.
    Im hoping it will be fixed and done Thursday. If not Im ganna demand a new front diff. there trying to just re-build it and its bull!
    If it goes away in 4wd then its the Needle bearing.
    Sorry, but alot of Tacomas have this issue.
  10. Jan 18, 2011 at 2:46 PM
    Bumponapickle
    Bumponapickle Well-Known Member
    Ontario, Canada
    09 TRD + Leather DCLB
    Old Man Emu 3 inch lift + AAL, Satoshi and Pioneer Avic Z130BT
    What kind of lift did you install? I have an old man emu with 855 springs and spacers...09 dclb...never had any vibes from it.
  11. Jan 18, 2011 at 2:54 PM
    ETaco23
    Evan
    PNW
    Its more of a growning/growling noise and a grinding slight vibe in the floor board that most people feel.
  12. Jan 19, 2011 at 5:38 AM
    jigger1976
    ontairo
    how long did you have the lift in for? before the bearing went? and how much for the needle bearing,it is hard to get to.
  13. Jan 19, 2011 at 5:44 AM
    Alby9999
    Alby9999 Well-Known Member
    Alby
    NNJ
    07 AC TRD OR Impulse Red
    TRD Cat back exhaust 3" FR lift-AAL CAI-Ram air D rings Tail gate theft mod 4x4 illumination switch mod Redline hood struts Fogs on any time mod diff breather relocation mod 886 reverse light mod Wet Okole Avid weld on sliders LR UCAs Locker mod 115 in cab outlet 400w anytime
  14. Jan 19, 2011 at 8:06 AM
    jigger1976
    ontairo
    Hey bump where u for in ontario??. again does anyone know the poper angles for drive lines front and shaft. the nosie is getting worse but the temp has dropped to -23
  15. Jan 19, 2011 at 10:37 AM
    ETaco23
    Evan
    PNW
  16. Jan 19, 2011 at 6:08 PM
    jigger1976
    ontairo
    how long did you bearing last? since you put the lift in. and how much was it to replace
  17. Jan 19, 2011 at 6:59 PM
    ETaco23
    Evan
    PNW
    The Lift doesnt cause the bearing to go bad, it just makes the bad bearing present. I drove it for maybe 30miles after the lift, then took it to the dealer. I have the ext. warrenty so there covering it. there just being stupid and trying to rebuild it, instead of just replacing it. My truck wouldve been done a week ago if they just gave me a new diff.
    theyre ganna take my diff apart again to replace another part, bc the thing they replaced the first time didnt work.... Im just heated!! sorry for the rant!
    its been about 2.5 weeks without my baby!
  18. Jan 19, 2011 at 8:15 PM
    jigger1976
    ontairo
    call me stupid but i can't get my head around this. so your saying eveyones bearing is bad then.????? because everyone who is hearing this growling means the bearing is bad or is the lift affect it some how. if you take the lift out you don't hear it growling. SORRY for the rant!! but this nosie is driving me crazy!! but i LOVE the look of the truck
  19. Jan 19, 2011 at 8:52 PM
    ETaco23
    Evan
    PNW
    Its all good, I was pissed when I heard it the first time also.
    But no, it seems to be hit and miss. some people have it and some dont. When lifting, your cv axles put more load on the bearing there for you can hear and feel the bad bearing. but when your truck is stock and the cv's are in there neutral position you cant hear/feel it. hope that makes sence.
    How most people find out if its the Diff bearing is by seeing if the noise goes away in 4wd. but if its still there then its most likely a wheel bearing or something else.
  20. Jan 19, 2011 at 10:19 PM
    jigger1976
    ontairo
    thx that makes sense now. and ya it goes away in 4wd. thx again
