Need advice on purchasing Limited vs Off-road model
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cvn72, Jul 18, 2016.
  1. Jul 18, 2016 at 3:14 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Chrome and leather can be purchased and added for less than bilstein suspension, MTS, crawl control, and rear locker.
  2. Jul 18, 2016 at 3:15 PM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Did you put ARB rear locker? If so what size locker did it take?
  3. Jul 18, 2016 at 3:17 PM
    smitty99
    Scottsdale
    If you're buying a 4x2 I see absolutely no reason to get a TRD OR
    Sbpark likes this.
  4. Jul 18, 2016 at 3:19 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    100% correct, but I don't require the OR crawl control etc. I did want leather, JBL (only in Canadian Limited, not optional on any other model), running boards, etc.
    Different strokes for different folks.
  5. Jul 18, 2016 at 3:19 PM
    ctfriel
    ctfriel @Overland_NC
    Winston-Salem, North Carolina
    2017 TRD OR AT (@overland_nc)
    Basic overland stuff...
    Most people change the suspension. Not concerned with warranty on a rear axle. If an ARB broke so would the stock unit. Dealer wouldn't warranty either. Actually ARB probably would. Also learning to drive is worth way more than crawl control.
    nomnomtaco and CanadianJames like this.
  6. Jul 18, 2016 at 3:20 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Get the LTD, it has most all of the creature comfort to get you by, and take you wherever you need to go and then some.
    The OR is a bit overkill IMO unless you like to impress your OR buddies.
    Hope that helps
    Cheers!
    Sbpark and CanadianJames like this.
  7. Jul 18, 2016 at 3:21 PM
    CanadianJames
    CanadianJames Member
    James
    Tsawwassen BC
    2014 Tacoma
    I use to drive a Subaru STI, and it was a great car, and I would follow my buddies into the bush until we'd come up to an obsticle, then I'd park it and get in with them... which was the shits
    So I then switched to a 2014 Tacoma without the rear locking diff as it was my daily driver only to be driven offroad every once in a while. When I started driving it offroad more, I decided I wanted a locker, and installed an ARB selectible rear locker and it works great... so my advice in your case would be to get the truck without the locker and add it in the future if you find yourself getting the offroad itch. Having or not having a rear locker won't really change the value of the truck a whole bunch on resale as it's not super duper expensive to add one on
  8. Jul 18, 2016 at 3:22 PM
    smitty99
    Scottsdale
    My rear diff has already failed. Dealer said without warrant it would have set me back over 3 grand
    The hammer likes this.
  9. Jul 18, 2016 at 3:23 PM
    smitty99
    Scottsdale
    Right. My point is for the money you get much more stock capability in the OR. Both trucks cost about the same. The limited only adds some cosmetics and comes up short on performance if compared to the OR
  10. Jul 18, 2016 at 3:25 PM
    ctfriel
    Not yet. Should be same as 2nd gen rear. Supposedly some 3rd gen ORs got a larger ring gear...
  11. Jul 18, 2016 at 3:26 PM
    ctfriel
    You can build a pretty nice 60 or 9" for that.
  12. Jul 18, 2016 at 3:27 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Well that would be you just getting ripped off by them then. New diffs aren't that much.
    CanadianJames likes this.
  13. Jul 18, 2016 at 3:30 PM
    CanadianJames
    James
    Tsawwassen BC
    2014 Tacoma
    From what it sounds like this guy isn't going to need his warranty with the way he drives it
  14. Jul 18, 2016 at 3:39 PM
    eon_blue
    Azusa, CA
    Correct, a locker in the snow will likely just cause more problems for you traction-wise. For snow driving, you want good tires for the job and 4hi or 4lo depending on what speed you can safely go.
  15. Jul 18, 2016 at 4:15 PM
    #35
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    A Limited with 4WD will work just fine for the OP while running the street in Illinois. If the factory stuff doesn't do the trick on snowy days - decent snow tires, a Detroit True-Trac in the rear end and a few sacks of salt in the bed will finish the job. And maybe a trip to the undercoater....
    All of the truly capable "Off Road" trucks you see here on TW - are loaded with aftermarket parts - that will also fit your nicely finished Limited.
  16. Jul 18, 2016 at 4:52 PM
    #36
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Love my Limited...my use is the same as yours will be. Didn't seem expensive because I got exactly what I wanted without having to modify/add stuff myself down the line. Instant gratification!
  17. Jul 19, 2016 at 2:48 PM
    #37
    cvn72
    cvn72 [OP] Member
    Manny
    Just got my Tacoma limited. Feels a little sluggish below 3k rpm. Made an appointment to get that TSB 0077-16 done. Hopefully it will bring a little more oomph in the low rpm ranges. Otherwise, love the truck so far.
    damnfingers and Arcticelf like this.
  18. Jul 19, 2016 at 2:52 PM
    #38
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    You chose, Wisely.
  19. Jul 19, 2016 at 8:25 PM
    #39
    Lovci
    Lovci Well-Known Member
    2017 White Tacoma SR AC 4cyl M/T
    Most people will never have a need for a locker. Even those that hit the back roads often. I went through plenty of gnarly trails in my Rubicon and the locker was never even remotely necessary. 4 low and some skill was plenty.
    The hammer and smitty99 like this.
  20. Jul 19, 2016 at 9:13 PM
    #40
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Limited looks better with the painted rear bumper. Other than that it's just interior features that you spend more cash on. I have the OR model and I love it because I use it rock crawling. The locking rear diff from the factory is too good of an option to pass up in my opinion. Also the OR model (auto transmission model) has a beefier rear diff for strength/payload/towing.
