Need advice on rear LT
Discussion in 'Long Travel Suspension' started by Zlagger, Mar 27, 2012.
  1. Mar 27, 2012 at 10:41 PM
    Zlagger
    Zlagger [OP] Well-Known Member
    Rich
    Santa Cruz
    2010 DBCab TRD Long Bed
    AllPro LT front -w- Fox 2.5 COs, rear AllPro 3" springs -w- King 2.0 shocks
    I just finished installing an AP front LT kit. Now I am starting to think about SUA... Looking to do it right the first time. What kit or individual components would you buy?
    Notes:
    2010 Tacoma DBL Cab Long Bed
    Front All-pro LT -w- tons of gussets on order
    Running 33" tires.
    Pics coming...
  2. Mar 27, 2012 at 10:53 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    the defined kit would be sweet
  3. Mar 27, 2012 at 11:08 PM
    Zlagger
    Rich
    Santa Cruz
    Know anyone running their 2005-12 Tacoma 6-lug Spring under conversion kit?
  4. Mar 27, 2012 at 11:10 PM
    anthony250f
    Anthony
    San Diego, CA
  5. Mar 27, 2012 at 11:24 PM
    Zlagger
    Rich
    Santa Cruz
  6. Mar 28, 2012 at 7:03 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    how much weight will you have in the bed?
  7. Mar 28, 2012 at 7:10 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Eddie (Special K), jlatchac08 (Jermey, not sure on username), OakleyTRD (on TTORA paired with the AP LT as well) are all running the kit with great results & reviews :cool:
  8. Mar 28, 2012 at 8:42 AM
    Zlagger
    Rich
    Santa Cruz
    Some tools, full size tire on a tire gate, maybe 200 lbs Max.
  9. Mar 28, 2012 at 8:42 AM
    rcfreak201
    rcfreak201 Well-Known Member
    if you go the defined route you will be fine with the regular leaf pack, no need for his XL pack.
  10. Mar 28, 2012 at 8:45 AM
    Zlagger
    Rich
    Santa Cruz
    Thanks for the info. The defined kit looks super simple to install, just wasn't sure about how well it takes abuse and how well it performs compared to a peiced together custom kit.
  11. Mar 28, 2012 at 8:46 AM
    rcfreak201
    for second gens its really not worth piecing them together since so many companies offer complete kits that will probably run cheaper than piecing it anyways
    edit: mike has been running his kit for about 2 years IIRC and it has seen ALOT of abuse from chasing to just playing around in the desert. He's still running on his first set of leaf springs and theres no sign of sagging even with the weight in his bed.
  12. Mar 28, 2012 at 9:09 AM
    Zlagger
    Rich
    Santa Cruz
    Hmmm sounds promising:thumbup:
  13. Mar 28, 2012 at 9:11 AM
    Zlagger
    Rich
    Santa Cruz
    It looks like his hoops are pretty much vertical... So shocks must be 16's
  14. Mar 28, 2012 at 9:13 AM
    theduck911
    Max
    Locked and Geared!
    Yes, the shock hoops Defined sells is designed to run a 16" stroke shock w/ their kit :cool:
  15. Mar 28, 2012 at 9:20 AM
    Zlagger
    Rich
    Santa Cruz
    Ill give defined a call today. Then I will need to look into bed sides next.
  16. Mar 28, 2012 at 9:23 AM
    rcfreak201
    you can clear 33s with OEM bedsides and his bedside brackets ;)
  17. Mar 28, 2012 at 9:31 AM
    Zlagger
    Rich
    Santa Cruz
    Looking at the truck... I can't imagine it would work for my wheel/tires. They are so wide. Would be sweet though
  18. Mar 28, 2012 at 9:33 AM
    rcfreak201
    not sure honestly, ask mike when you call, he has OEM bedsides and 33s with his kit and its fine. super sleeper status :cool:
  19. Mar 28, 2012 at 11:40 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Does the defined kit outboard shocks?
  20. Mar 28, 2012 at 12:37 PM
    Zlagger
    Rich
    Santa Cruz
    Sounds like it should just barely work (with some cutting)
