Need Advice on rear shocks for 4" lift
Discussion in 'Suspension' started by Toy Yoda, Dec 11, 2011.
  1. Dec 11, 2011 at 11:12 AM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    Current Set up
    Front: 5100's and 886's with ARB, bout 2.75-3" of lift
    Rear: 2" blocks and stock SR5 shocks
    I want to bump up everything to about 4", so i was thinking about OME's little spacer plates for up front, and maybe some rear 4" blocks temporarily (until i get a leaf pack this summer) in the back. What rear shocks would function well with 4" blocks? i was looking at OME N182's but wasn't sure if they're made for that much lift. I'm also not looking to break my bank on these shocks.
    edit: i'll probably keep the 2"blocks and put a 2" aal
  2. Dec 11, 2011 at 11:14 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Bilstein 5125s come in custom lengths for the rear. Check them out at downsouthmotorsports.com
    It's not recommended that you go over 3" of lift in the front.
  3. Dec 11, 2011 at 11:14 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    you'll probably want some 10" travel bilstein 5125's or similar
  4. Dec 11, 2011 at 11:14 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    It will go above 3", many guys running close to 3.5" of lift....it is highly NOT recommened but can be done.
  5. Dec 11, 2011 at 11:21 AM
    08pretaco
    Oliver
    az
    There we go :p
    I realized what you were saying just wanted to be a butthead lol
  6. Dec 11, 2011 at 11:24 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I got close to 3.75 up front with the 885's and top plate spacer....but now it settled to closer to 3.25
  7. Dec 11, 2011 at 11:25 AM
    Toy Yoda
    Garrett
    06 DCLB
    aw yeah...wasnt thinking about the steep angles and all that, now i'll most likely go with the dakars and N182's just to get rid of the bro lean and crappy ride
  8. Dec 11, 2011 at 11:28 AM
    Toy Yoda
    Garrett
    06 DCLB
    which spacer plate did you go with sean?
  9. Dec 11, 2011 at 11:29 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    the 1/2 inch spacer from toytec, it was a option to add the top plate spacer when buying the complete kit
  10. Dec 11, 2011 at 11:35 AM
    Toy Yoda
    Garrett
    06 DCLB
    oh gotcha, i was looking at the OME 13mm (3/4-7/8") plate, i figured it'd be alright
  11. Dec 11, 2011 at 11:37 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
  12. Dec 11, 2011 at 11:41 AM
    Toy Yoda
    Garrett
    06 DCLB
    wow thanks man i was just on wheelers, would it make a difference with the lift if i said my truck was a pre runner:spy: like would it be okay to go up to about 4"?
  13. Dec 11, 2011 at 11:42 AM
    08pretaco
    Oliver
    az
    no it wont because you will have 0 downtravel. if you really wan to do 4" your going to have to fork over 1k for Camburg spindles
  14. Dec 11, 2011 at 11:44 AM
    RelentlessFab
    Eric
    If you've got a prerunner at least you dont have to worry about cv angles. Just UCA ball joints(you better get aftermarket UCAs if you dont have them already), and steering component wear from the steep angles. But you still wont have down travel with 4" of lift cranked...
    But if you want more lift... 4" lift Spindles?
  15. Dec 11, 2011 at 11:47 AM
    Toy Yoda
    Garrett
    06 DCLB
    yeah i've looked at spindles, I'm just not looking to spend that much money right now is all, i'll probably keep the front like it is and just bump the rear up to 3, for now :D
  16. Dec 11, 2011 at 11:47 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Torsion bars?
  17. Dec 11, 2011 at 11:48 AM
    08pretaco
    Oliver
    az
    older toyota trucks use torsion bars yes! IIRC up till '95 is when they used them
  18. Dec 11, 2011 at 11:49 AM
    jflan
    Vancouver, WA
    This.
    You're a Prerunner ?
    If yes, spindle lift for the front.
    No half-shafts to worry about.
    Get real lift springs (Alcan, Deaver etc.) for the back though.
    And you may want to entertain this CB drop kit if you go 4"
    http://www.streetacos.com/Products.html (select carrier bearing drop kit from the drop-down menu)
    Degree shims on the rear perches and extended brake lines might be needed as well.
    No free lunches :D
  19. Dec 11, 2011 at 11:51 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, my 88 has them. I wasn't aware he had an pre-taco.
  20. Dec 11, 2011 at 11:52 AM
    Toy Yoda
    Garrett
    06 DCLB
    summer time for sure when i have money, am i understanding this correctly that 4" spindles would add 4" off lift to my current 3" up front? I've been kinda confused about that
