Need advice on Rear shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyle Gentz, May 3, 2013.
  1. May 3, 2013 at 1:42 PM
    Kyle Gentz
    Kyle Gentz [OP] Camera Guy
    06 Tacoma 4x4 4Door Short Bed
    I did a search couldn't find my answer.
    My rear shocks are no good. Need new ones, I figure aftermarket is the way to go. Also I have an ARE Tradesman (metal) camper shell and keep about 100-300lbs in the bed on a regular basis for work. Also I do pull a 3000lb trailer from time to time. What would you guys recommend?
  2. May 3, 2013 at 1:50 PM
    ManMan
    ManMan Well-Known Member
    Weight really doesn't affect shocks unless you change your springs.
    Dirt cheap, low mile used Bilsteins from the classifieds.
    Next, 5100's.
    Nice, Fox 2.0's
  3. May 3, 2013 at 1:52 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    Its probably not your shocks that are bad but the leaf springs. You probably need new shocks too, but shocks do not carry a load your leaf springs do. You are looking at around $350 to $400 for new springs. Check out Wheelers, Toytec and Down South motor sports. Bilstein 5100 shocks are good middle of the road shocks.
  4. May 3, 2013 at 2:24 PM
    Kyle Gentz
    suck, the truck is sagging pretty bad, A shop told me it was the shocks. So it sounds like both. Are new leafs hard to install? Also It bottoms out just driving over a valley gutter.
  5. May 3, 2013 at 8:13 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
  6. May 3, 2013 at 8:18 PM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    if its sagging its most likely due to the leafs, the shocks just dampen the bumps. I did my rear lift the other day and it was pretty simple. Its basically what you would be needing to do when you do your shocks and leafs. Trust me all new everything makes for a nice ride. Threw skyjacker 7000s in there at the same time , cant really beat 40 a shock
