Need advice on rear suspension, please!
Discussion in 'Suspension' started by RicardoM, Dec 24, 2013.
  1. Jan 8, 2014 at 8:51 AM
    #81
    RicardoM
    RicardoM [OP] Well-Known Member
    Hermosillo, Son, MX
    2007 Taco dbl cab 4x4 manual trans
    Completely stock for now... looking for a good smooth lift kit
    The leafs are already sag. With no load.
  2. Jan 8, 2014 at 10:16 AM
    #82
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    Deaver really should stop selling the j66
  3. Jan 8, 2014 at 1:48 PM
    #83
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I went ahead and ordered the Timbren bump stops from Wheelersoffroad. $195 for the rear set. The part numbers are TORTUN4L for the 3-leaf OEM springs, and TORTUN4 for the 4-leaf OEM pack. For you, anybody lifted, or different spring packs like Deaver, I guess you have to measure the gap from spring to frame. See the discussion link below, there is some 5.75" Timbrens available as well as spacers, I think the standard height on the TORTUN4 is about 3.5".
    Here's a good discussion about them:
    http://www.toyotanation.com/forum/6...o-work-great-some-more-detailed-analysis.html
  4. Jan 8, 2014 at 8:47 PM
    #84
    RicardoM
    Hermosillo, Son, MX
    Well, that only will reduce the sudden bump hit... it will not solve the problem. On weekends I like to wheel, go camping, etc... at least once per month I haul a camping trailer or a boat. These leafs will not handle any kind of load, neither just "coolers".
  5. Jan 8, 2014 at 9:37 PM
    #85
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    & barely that... I live close to Mexico, about 20 miles as the crow flies
  6. Jan 9, 2014 at 4:01 PM
    #86
    monkeyface
    Colorado
    Well, the Timbrens are called a "supension enhancement system". So it's not like having the great load-carrying springs like the Dakar CS047. That was what was recommended to me, but the 2.5" lift I didn't want. Also cost difference, ease of install (or de-install in the case of the Timbrens). I can see there will be a time when unhooked from the trailer I'd want to yank them.
    By the way, the part numbers I listed above have one significant difference - the TORTUN4 is 6000lb capacity, the TORTUN4L is 3000lb capacity, so obviously one will be stiffer than the other. The TORTUN4 is for both the Tundra and the Tacoma 2nd Gen.
    Best of luck to you . . . . .
  7. Jan 9, 2014 at 7:58 PM
    #87
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why didn't you just get airbags ?
  8. Jan 10, 2014 at 12:54 PM
    #88
    monkeyface
    Colorado
    Cost, ease of install and de-install, and I read some good things about the Timbrens. Hope I don't hate them and end up with airbags after all.
    The WDH for the trailer was a disaster, it's gone now and a $36 straight hitch and ball on there . . . . I hope these Timbrens don't mirror that.
  9. Jan 10, 2014 at 12:55 PM
    #89
    OZ-T
    Peter North
    British Columbia
    Just wondering cause it seems it would be a lot easier to inflate / deflate airbags than swapping Timbrens for stock bumpstops every time you carry a load
  10. Jan 10, 2014 at 1:13 PM
    #90
    monkeyface
    Colorado
    From what I read about the airbags even deflated to the minimum they interfere with full articulation, so I figured go with the cheaper simpler solution, and if I want full articulation for the brutal roads I'll just have to get under the truck and swap them out. Supposedly it's about 15 minutes per side, loosen the Ubolts, wrench them out, wrench the other ones in, retorque the Ubolts.
  11. Jan 10, 2014 at 1:15 PM
    #91
    OZ-T
    Peter North
    British Columbia
    I thought U bolts weren't supposed to be repeatedly undone and re-torqued
  12. Jan 10, 2014 at 1:23 PM
    #92
    monkeyface
    Colorado
    This I don't know about either way. They're pretty stout bolts.
  13. Jan 26, 2014 at 8:06 PM
    #93
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
  14. Jan 27, 2014 at 6:09 AM
    #94
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  15. Jan 27, 2014 at 9:23 AM
    #95
    RicardoM
    Hermosillo, Son, MX
    And you send that to Deaver and they say "There is no problem there, that's how it should be. Sell them to another one and buy us another model for your application"!!!
    I'm going to put them on my son's go cart.
  16. Jan 27, 2014 at 9:54 AM
    #96
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Why fuck up a good Go Kart Ricardo ??....:D
  17. Jan 27, 2014 at 11:29 AM
    #97
    RicardoM
    Hermosillo, Son, MX
    HAHAHA, good one! It is somewhat depressing to have thrown away 625 dlls (plus expensive shipping). And as paperweights are a little big. The only thing I can think of is to use them in any application completely weightless.
  18. Feb 3, 2014 at 2:43 PM
    #98
    monkeyface
    Colorado
    One more thing about these Timbrens. I've noticed I don't get as much vibration in that 18-20 MPH range since I installed them.
    With the trailer hooked up the vibration was pretty bad. Since the Timbren install with the trailer hooked up that vibration has decreased noticeably. . . .
    Why that is I do not know.
