Need advice on removing supercharger- 2004 3.4L manual 4x4 XCab
Discussion in 'Technical Chat' started by TReD4x4SuprChrg04, Oct 12, 2016.
  1. Oct 12, 2016 at 2:47 PM
    TReD4x4SuprChrg04
    TReD4x4SuprChrg04 [OP] New Member
    Red 2004 Taco XCab 4x4 3.4L Manual SuperCharged
    I need some advice/help. I am trying to remove the supercharger off my 2004 3.4L manual 4x4 taco. The truck is reading the P0325 knock sensor code so I have removed the air intake, throttle, and all the vacuum hoses in attempt to change the sensor and the wire harness. I have also removed all the bolts and screws that I can see. But with all that done, the supercharger is not budging an inch. Am I missing a bolt or screw somewhere?
    The supercharger is the first gen TRD Magnuson. I have researched and watch probably all the youtube videos and havent yet found a helpful solution.
    Help!! Thank you!!
  2. Oct 12, 2016 at 11:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
